Kohler K-series Connecting Rod Question?
k 321 connecting rod undersized markings
6 replies to this topic
#1 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,836 Thanks
  • 1,582 posts
Posted February 07, 2018 - 07:32 PM
I have a K321 crank and connecting rod.  Besides measuring the crank end of the connecting rod, how can you tell if it's an underside rod?  I know pistons will be marked with .010, .020, or .030.  Do they do the same thing with connecting rods for the Kohlers?  Is there also a way to tell if the connecting rod is a Kohler made part or an aftermarket part?
Thanks
  • propane1 said thank you
#2 propane1 OFFLINE
propane1
  • 9,451 Thanks
  • 4,389 posts
Posted February 07, 2018 - 07:43 PM
Great question. I want to hear too. I for some reason don’t think they are marked. But I could very well be wwwwrrroong. You said undersized rod. Would it not be oversized rod and undersized crank journal. Just wondering. I always get that stuff mixed up.
Noel.
  • Mark 149 J. said thank you
#3 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,836 Thanks
  • 1,582 posts
Posted February 07, 2018 - 07:57 PM
Noel.
I believe you're correct!
If they turn the crank journal down by .010 then the connecting rod would be oversized by .010.
  • boyscout862 and propane1 have said thanks
#4 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted February 07, 2018 - 08:08 PM
yes you can get Kohler rods
Kohler rods should have Kohler;s number mark on them
found this from a Kohler Parts Manual for a K321
the part manual is in the manual section
http://gardentractor...p-parts-manual/
Edited by lyall, February 07, 2018 - 08:21 PM.
  • Alc, boyscout862 and Mark 149 J. have said thanks
#5 GardnMastr OFFLINE
GardnMastr
  • 399 Thanks
  • 203 posts
Posted February 07, 2018 - 08:14 PM
Factory Kohler .010 undersize connecting rods have a small hole drilled in the web of the beam nearer the big end. I've seen 30 or 40 of them.
  • Alc, EricFromPa, HANKG and 1 other said thanks
#6 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted February 07, 2018 - 08:17 PM
You really have to get mics or calipers that measure to 0.0001". The crank needs 9 measurements on the rod journal. I am not sure how many on the rod. The Kohler inspection sheet shows how to measure it all and the Kohler Manual will give the specs. I always use plastic gauge too just to be sure. Good Luck, Rick
  • propane1 and Mark 149 J. have said thanks
#7 secondtry ONLINE
secondtry
  • 2,158 Thanks
  • 1,531 posts
Posted February 07, 2018 - 11:25 PM
  I believe the rod would be 10 under same as the crank. You are measuring the hole in the rod and that would have to be 10 tho smaller or under to maintain oil clearance. If the hole was 10 over it would be very lose and sloppy.   Don
  • boyscout862, LilysDad, HANKG and 2 others have said thanks
Also tagged with one or more of these keywords: k 321, connecting, rod, undersized, markings
