Wanted
112 John Deere relay
7 replies to this topic
#1 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 07, 2018 - 05:36 PM
I have a John Deere 112 that has the electric clutch for the mower deck, It has a relay type fuse Part number AM34495. No longer available. Does anyone out there know where I might find one?
#2 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted February 07, 2018 - 06:17 PM
The John Deere site shows this is for the Clutch brake is that why not are looking for it
  • Traill95 said thank you
#3 GardnMastr OFFLINE
GardnMastr
  • 378 Thanks
  • 191 posts
Posted February 07, 2018 - 08:36 PM
I looked at the JD parts website, but could not discern what it looked like or the arrangement of the terminals. Do you have a picture of the old one?
#4 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 08, 2018 - 08:40 AM
it is for the Electric Clutch/Brake and from what I have found so far it was only on there for one year.
#5 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 08, 2018 - 08:46 AM
here are pics of it.
It has 4 posts 2 posts have ultra thin wires running to the thicker fuse links. As you can see this one is burnt out.
#6 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted February 08, 2018 - 08:43 PM
Did you find a a problem somewhere else looks like something caused that  just thinking out loud here
#7 dodge trucker ONLINE
dodge trucker
  • 2,404 Thanks
  • 3,100 posts
Posted February 09, 2018 - 06:53 AM
probably fatigue from old age.....
#8 GardnMastr OFFLINE
GardnMastr
  • 378 Thanks
  • 191 posts
Posted February 10, 2018 - 08:30 AM
Unless you're totally restoring the machine, I would install an inline blade fuse holder and a little square relay. Electric power take offs should only pull about 2 amps. Have you inspected your pto coil to see if the windings or potting epoxy is swelling. Your charging system maxes out at 15 amps, other loads are battery charging, headlights, taillights, ignition coil, and operator presence wiring.
