3 point hitch or a loader , which one.
20 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,443 Thanks
  • 4,384 posts
Posted February 07, 2018 - 09:53 AM
Which one would you want on your garden tractor. And ya can’t say both !
If two tractors were exactly the same, one had a 3 point hitch and the other a loader, which one would you buy. Or if you had the option of buying a 3 point hitch or loader for your tractor. Which one would you buy.
Just curious.
Noel
  • boyscout862, SupplySergeant, Leonard VanCamp and 3 others have said thanks
#2 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted February 07, 2018 - 10:01 AM
With me, it would be the loader! It's a lot easier to add a 3-point than to find a loader!
  • boyscout862, dropped82, SupplySergeant and 5 others have said thanks
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted February 07, 2018 - 10:10 AM
Loader all the way.
  • boyscout862, dropped82, SupplySergeant and 2 others have said thanks
#4 Greasy6020 OFFLINE
Greasy6020
  • 1,627 Thanks
  • 1,495 posts
Posted February 07, 2018 - 10:12 AM
I'd take one of each!
As far as I'm concerned a loader would be far more handy, I already have a tractor with 3 point hitch. It doesn't run though...
#5 toppop52 OFFLINE
toppop52
  • 5,538 Thanks
  • 4,901 posts
Posted February 07, 2018 - 10:19 AM
One or the other, loader every time, but add th3 3 point, it’s also a big winner.
#6 chieffan ONLINE
  • 11,341 Thanks
  • 7,106 posts
Posted February 07, 2018 - 10:21 AM
Loader for a QT.  Have the 3 point on the White 1655.
  • boyscout862, dropped82, SupplySergeant and 1 other said thanks
#7 sharkman OFFLINE
sharkman
  • 403 Thanks
  • 321 posts
Loader for a garden tractor,  maybe a 3 point on a farm tractor would a closer competition.
#8 MiCarl ONLINE
MiCarl
  • 2,206 Thanks
  • 1,122 posts
Posted February 07, 2018 - 10:45 AM
I love having a 3 point, but bet I'd get more use out of a loader.
#9 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted February 07, 2018 - 11:13 AM
Loader
#10 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 07, 2018 - 11:17 AM
A loader would make my tractor too long for mowing.  I also like to garden so I need a 3 pt hitch.  I think the solution is 2 tractors. One for each.
#11 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted February 07, 2018 - 11:51 AM
I could use a loader often and they are not cheap or easy to come by for my tractors, so I would opt for a loader even if it meant to be a stand alone loader/tractor and only used on occasion. 3pt (manual lift) for the sears are abundant and I really don't need more then that so LOADER.
Now if its just a loader or a 3 point ,  would still say loader only thing I have that uses a 3pt is a tiller so I could find another way.
#12 boyscout862 ONLINE
  • 13,551 Thanks
  • 9,427 posts
Posted February 07, 2018 - 11:58 AM
My Ford 2000 has both and needs both at the same time. Without the counter weight on the 3 ph, the FEL wouldn't be able to lift as much and the tractor would get stuck alot. On a GT, the FEL wins. I don't have a 3 ph on any of my GTs. I'm content with sleeve hitches and the AC/Simplicity hitches. I'm finding that the hitch type isn't as important as having the power lift(electric or hydraulic). Good Luck, Rick
  • dropped82, SupplySergeant and propane1 have said thanks
#13 Allis Chalmers Tractors ONLINE
  • 83 Thanks
  • 41 posts
Posted February 07, 2018 - 02:11 PM
I like having the hitch for working the garden and would rather use a tractor or skidloader for liifting.
  • boyscout862, SupplySergeant and propane1 have said thanks
#14 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 2,011 Thanks
  • 1,092 posts
Posted February 07, 2018 - 03:33 PM
Loader for general work around the property, three-point for ground engaging tools.
  • boyscout862 and propane1 have said thanks
#15 glgrumpy OFFLINE
  • 8,810 Thanks
  • 8,014 posts
Posted February 07, 2018 - 04:11 PM
I used to want a loader and had a PK for short time. Little ones aren't that useful I don't think. I used to be doing lots of changes in yard and building stuff, changing landscape. Now that I'm older and not so much into the changes, I really don't think I would get much use out of a loader anymore. The 3pt can be used on lots of blades and can make a lift platform that would probly do all the work I wanted and other items I can't think of now. AND, with 3pt, attachments don't have to be brand specific to mount then. SO, gonna be different here, (a rare occurrence), heh, and say 3pt at my place.
