100% Gasoline
22 replies to this topic
#1 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,108 Thanks
  • 10,181 posts
Posted February 06, 2018 - 07:53 AM
In my area Casey's has been offering E10 gasoline 87 and 89 octane for years. Well, in DeKalb, a new Casey's has gone up on the East Side which also offers E15 and straight gas. My mowers are going to be doing their happy dance.
  • Gtractor, hamman, KennyP and 6 others have said thanks
#2 cootertom OFFLINE
cootertom
  • 1,632 Thanks
  • 843 posts
Posted February 06, 2018 - 08:01 AM
I've been lucky enough to have always get 100% gas within 1/2 mile of where I live. Bad thing it is a country store and it ain't cheap. About 50 to 60 cents a gallon more but I use it in mowers. tractors and chainsaw. I bought a 80 volt weedeater and leaf blower last spring and so far both have done well.
  • hamman, KennyP, Cvans and 4 others have said thanks
#3 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted February 06, 2018 - 09:12 AM
I've been getting 'ethanol-free' gas for a couple years now. Small engines love the stuff.
  • hamman, Cvans, Leonard VanCamp and 2 others have said thanks
#4 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted February 06, 2018 - 09:19 AM
I pay 3.75 a gallon for str8 gas and won't use anything else unless I am forced to.
#5 Doug E. ONLINE
Doug E.
  • 398 Thanks
  • 206 posts
Posted February 06, 2018 - 09:20 AM
In my neck of the woods, we have been able to get ethanol free premium gas for at least the last 10 years.  I used to have to drive to the next town to get it, but more stations are carrying it locally now.
However, if the pump uses one hose for the different grades of gas, you do end up with the residual of the ethanol gas in the hose (and probably the pump) in your container before the ethanol free premium starts coming out.  Fwiw.
D.
  • hamman, Cvans, LilysDad and 2 others have said thanks
#6 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,597 Thanks
  • 2,908 posts
Posted February 06, 2018 - 10:29 AM
Here in Northern Michigan they call it Rec Gas. It is all I use in all of my small engines and in the three Allis Chalmers Farm Tractors we have. Costs more but doesn't affect the carbs as bad as the blended ethanol gas does. Had to change the fuel line three times in year on my chain saw before switching gas.
Roger
  • Cvans, Leonard VanCamp, Reed Breneman and 1 other said thanks
#7 Reed Breneman OFFLINE
Reed Breneman
  • 2,770 Thanks
  • 878 posts
Posted February 06, 2018 - 10:31 AM
I find it odd ???Maybe? that you have to pay extra for straight gas,We have 2 local stores ,1 Caseys and a Cenex store that sell ethanol free and its the same price as the ethanol crap or real close
#8 Bob White12 OFFLINE
Bob White12
  • 140 Thanks
  • 136 posts
Posted February 06, 2018 - 10:33 AM
my old hit n misses run better in my opinion on diesel than that ethanol crap they have now. I had to start putting that special classic oil in all my antique cars now because that ethanol is so bad on em.
  • Leonard VanCamp and AdamTheWebMan have said thanks
#9 Trav1s ONLINE
Trav1s
  • 3,577 Thanks
  • 4,550 posts
Posted February 06, 2018 - 03:11 PM
It depends on local tax rate or subsidies.  In Iowa and Nebraska the straight gas is $.10/gal more than the blended of the same octane rating.
  • Gtractor and Leonard VanCamp have said thanks
#10 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted February 06, 2018 - 03:12 PM
correction just went and filled up my tank this morning its 3.79 a gallon for str8 gas.
#11 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted February 06, 2018 - 03:25 PM
It's usually about the same as Premium around here.
#12 mmmmmdonuts ONLINE
mmmmmdonuts
  • 125 Thanks
  • 65 posts
Posted February 06, 2018 - 03:31 PM
I am fortunate to had straight gas for a while at a local gas station, but about a year or two ago a local chain of convenience stores started only offering 91 Premium gas as ethanol free at all its locations in addition to the 87, 89 e10 gas. They got rid of the 93 ethanol gas premium.
  • Leonard VanCamp said thank you
#13 chieffan ONLINE
  • 11,341 Thanks
  • 7,106 posts
Posted February 06, 2018 - 03:46 PM
I really get a kick out of you guys and your ethanol gas antics.  All I have ever used since it came out is ethanol blend in everything.  I use a stabilizer 90% of the time and have bad no problem in any of the tractors, mowers, chain saws, line trimmers or starting brush fires ( In small amounts with diesel and old oil).    Keep laying it on as I am always ready for a good laugh.  :rolling:
  • Gtractor and js5020 have said thanks
#14 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,795 Thanks
  • 5,094 posts
Posted February 06, 2018 - 04:31 PM
If you fill a tank and let it sit for 6 months before you burn it out you are going to have problems - doesn't make much difference with or without corn added.
  • shorty said thank you
#15 propane1 ONLINE
propane1
  • 9,443 Thanks
  • 4,384 posts
Posted February 06, 2018 - 04:32 PM
I use regular gas in every gas engine I own and have not any problems. Hi test is the only fuel that has no ethanol in it in my area, as far as I know. I put stabilizer in my gas cans, most times, when I fill them up. Should not have to use stabilizer either, if the gas was any good.
Noel
  • Cvans and Doug E. have said thanks
