Tea20 85mm Ferguson tractor. Need info !
8 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted February 04, 2018 - 07:50 PM
I’m wondering if any of you could give me the crankshaft rod journal size and the rod bearing to crankshaft journal oil clearance.
Seems hard to find any information. If any of you have access to a engine manual that has these engine specs, could you send it to me.
This is a tea20 tractor, not a te20 tractor. The Tea20 tractor has an English built Standard Motor.
Thanks for any help.
Noel
#2 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,175 posts
Posted February 04, 2018 - 08:57 PM
Try this from our Manuals Section: http://gardentractor...service-manual/
  • propane1 said thank you
#3 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted February 04, 2018 - 09:30 PM
Thanks. I looked in the manuals, but didn’t see it. It won’t let me download it. It says I’ve past my limit of downloads for today ??? I was looking at brochures, so maybe I did download to many ?
I’ll try tomorrow.
Noel
  • boyscout862 and James Bosma have said thanks
#4 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,175 posts
Posted February 04, 2018 - 10:10 PM
I’ll try tomorrow.
Noel
Brochures count, unfortunately. Use the search function in the Manuals Section to find what you want. How about some pics of your Fergie? Good Luck, Rick
#5 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted February 05, 2018 - 05:05 AM
Still does not work. Tryed the search. No luck there.
Noel
Could some one turn the upside down pictures, right side up. Thanks.
53C51483-EBA3-4705-999F-5D843D4CA8FF.jpeg     E23923C9-B707-4AEB-8870-47DD1D5D5573.jpeg
9BDDCFCC-9C5F-4E36-8D14-A7D532FF439F.jpeg     8FC3E762-8E2C-40FB-8107-F7390346D6E7.jpeg
Edited by KennyP, February 05, 2018 - 05:36 AM.
Adjust Gravity
  • olcowhand, KennyP and boyscout862 have said thanks
#6 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted February 05, 2018 - 05:52 AM
Thank you,
Noel
#7 boyscout862 ONLINE
  • 12,864 Thanks
  • 9,175 posts
Posted February 05, 2018 - 07:05 AM
In the last pic, I like how the GT next to it is green with envy. The Manuals Section used to have a 3 per day and 10 per week limits. Maybe you somehow exceeded that. I seem to be limited to 4 per day. Atleast it seems to be the exact manual you wanted. How is that for a coincidence?  Good Luck, Rick
#8 Rock farmer ONLINE
Rock farmer
  • 1,198 Thanks
  • 1,234 posts
Posted February 05, 2018 - 06:48 PM
Noel,
This is from my I&T manual.
The TE 20 was made in England.
The engine is from Standard motors.
I believe the TEA was a larger bore 80 or 85mm
The crank shaft dims may be the same.
Joe
If you can’t read it, it says
Journal dia 2.249 - 2.250
Running clearance .0015 - .0025
Cap screw torque 85 - 95 ft. Lbs.
#9 propane1 ONLINE
propane1
  • 8,725 Thanks
  • 4,131 posts
Posted February 08, 2018 - 04:32 PM
Well I got it to download, on to my computer in my garage. It would try to download on to my phone thing , but would only load so much then stop. Any way I got it and it looks great. Thanks for the help, and thanks KennyP for putting it on the site.
Noel
