Possibly too lose cutter deck belt on MTD 38"?
7 replies to this topic
#1 humpy OFFLINE
humpy
  • 3 Thanks
  • 9 posts
Posted February 02, 2018 - 03:53 AM
Just bought a MTD 38 " 2nd hand .. the cutter belt was snapped when purchased ... Manual says 77 7/8" belt..
I fitted a Kevlar belt, 76" internal = 78" OD  ( 3mm  bigger than official belt).. it  was WAY too loose!...
I then fitted a 75" ID belt  which  actually worked out at around 76.5" OD, when measured, which is a fair   jump in down sizing.. That one was definitely a wee bit  smaller than the old snapped belt when compared..
However it STILL seems too loose...  As soon as I started up the cutter  system, the belt  flaps  from side to side as shown in linked  video file 1, enough to put  vibration through the whole mower and even  makes the bonnet  flap a bit  ...also when stopped, but tension still on,, it is quite easy to push in with a finger....as shown in vid2
http://cybersol.com....mpup/mower1.mp4
http://cybersol.com....mpup/mower2.mp4
While collecting  belt at mowershop,  i had a look at the tension on the display  Rover/MTD mowers that were  nearly identical  design wise.
When i engaged the cutter belt  on these new machines, their  cutter belts were definitely tighter than mine even with the new smaller belt..
When fitting the  belt it easily fitted over the front drive pulley .. one size smaller I think would still juuuust  fit over without  straining  at it....
 Should I go to another inch size down perhaps?  loathe to spent another $40 for another belt, but no point flogging the mower out with a too loose belt...
 Many thanks
 Will
Edited by humpy, February 02, 2018 - 03:55 AM.
#2 chieffan ONLINE
  • 11,346 Thanks
  • 7,109 posts
Posted February 02, 2018 - 08:04 AM
How do the replacement belts fit in the pulleys?  Could it be the belts you using are to narrow for the pulleys and dropping down in to far?  Normally, the outside of the belt should run even with the rim of the pulley.  Could not view the videos in that format.  Just a thought.
Edited by chieffan, February 02, 2018 - 09:57 AM.
#3 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted February 02, 2018 - 08:43 AM
I'm not familiar with your exact machine but usually there is an adjustment that allows you to compensate for the belt stretching. Check our Manuals Section(3 free downloads per day) for the Operators(or Owners') Manual. It should tell how to adjust the tension. Sometimes that adjustment is in the front deck suspension linkage. If you have more questions, post some pics. That way we can visualize what you are up against. We are all in this together. Good Luck, Rick
#4 humpy OFFLINE
humpy
  • 3 Thanks
  • 9 posts
Posted February 02, 2018 - 09:12 AM
belt is brand new so nil stretching at this stage..  std half inch belt as per original manufacture specs..
happy to post further pics.
of which bits/what exactly ? and ill happily snap away..
 cheers
#5 Bolens 1000 ONLINE
  • 15,425 Thanks
  • 18,281 posts
Posted February 02, 2018 - 11:10 AM
You need an original spec belt, just because the length says its the same that dosent matter as OEM belts for these still were a special angle and v-groove
generic belts dont work on these riders
#6 secondtry OFFLINE
secondtry
  • 2,158 Thanks
  • 1,531 posts
Posted February 02, 2018 - 01:37 PM
    That much shake and vibration would make me suspect I had problems other than the belt. Blades out of balance, bad bearings, bent pulley/shaft, loose deck hangars. I have never had a loose belt cause any thing like that much shake. I have used generic belts and never developed vibration like that no matter how loose. The problem I generally have with generic belts is they don't last long enough to justify putting them on if i get them free.  Don
#7 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted February 02, 2018 - 02:44 PM
I am suspect of the tensioner working properly. Be sure to check it is under tension and that is not wobbling on it's shaft.
#8 jms180 ONLINE
jms180
  • 1,750 Thanks
  • 1,673 posts
Posted February 02, 2018 - 03:45 PM
i agree i always use MTD belts on MTD built products to match the belt angle to the pulleys
