My project
61 replies to this topic
#46 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 15, 2018 - 03:28 PM
It must of been the angle the camera.  I get 2 3/4 oil pan height and 2 3/4 for the dip stick the same as you.  I think you should be able to add 2 quarts. I can in my Kohler 321S.
#47 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,606 posts
Posted February 15, 2018 - 08:26 PM
I want to find a good factory tank. Mine was swiss cheese when i purchased the tractor. Any have a good tank for sale? Let me know.
Hi there is a fuel listed on e bay at the moment
#48 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted February 19, 2018 - 06:25 PM
Does anyone have any pointers on the fuel? Mine has quit. Do you guys use the plastic ones?
#49 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,606 posts
Posted February 19, 2018 - 06:29 PM
Hi not sure what your asking about, but if its a gas tank then there are no plastic gas tanks for the metal PK's
#50 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted February 20, 2018 - 07:48 PM
Sorry talking about the fuel pump
#51 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,606 posts
Posted February 20, 2018 - 08:03 PM
Hi the plastic one are fine been in use for years, if you get one just make sure you follow the instructions for installing/removing the fitting.
#52 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted March 07, 2018 - 12:56 PM
Could someone give me the tourque spec on the flywheel k321s.
#53 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,910 Thanks
  • 1,617 posts
Posted March 07, 2018 - 01:07 PM
50 to 60 ft lbs
#54 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted March 07, 2018 - 01:09 PM
Thanks. You guys are awsome.
  • Mark 149 J. said thank you
#55 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted March 07, 2018 - 01:24 PM
Need to tighten up my front end where it pivots on the tractor. Any advice? Is there a bushing?
#56 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted March 07, 2018 - 08:10 PM
I ended up putting the briggs pul s e fuel on. Seems to work good. So far.
#57 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted March 14, 2018 - 06:52 PM
#58 MNGB ONLINE
MNGB
  • 2,704 Thanks
  • 1,606 posts
Posted March 14, 2018 - 07:15 PM
Hi some tractors had needle bearing and others had a brass bushing  the bearing number I have is B1816 (timken) the bushing number is B13
  • Alc and Mark 149 J. have said thanks
#59 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted March 14, 2018 - 07:22 PM
Thanks
#60 Siman OFFLINE
Siman
  • 42 Thanks
  • 50 posts
Posted March 15, 2018 - 08:36 AM
Hey Fellows
I replaced my bearing plate gasket because of a leak. Didnt know they were also serving as a shim. After reading up on it I see they are. Is there a way to acuratley get the proper shims in place without pulling the engine apart?
