My project
61 replies to this topic
#31 Siman OFFLINE
Siman
  • 37 Thanks
  • 43 posts
Posted February 11, 2018 - 11:40 PM
Could someone measure and tell me how long there oil dip stick is? Looking at the kohler manual my k321 supposed to hold 2qts of oil. I changed my oil and put in 1qt. The dip stick says it is full. I am thinking this maybe the wrong dip stick?
#32 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 12, 2018 - 07:23 PM
I think you should run 2 quarts.  I don't use my dip stick. I go by the manual.  I think the dip stick is supposed to be dipped not screwed in.
#33 MNGB OFFLINE
MNGB
  • 2,625 Thanks
  • 1,569 posts
Posted February 13, 2018 - 12:05 AM
Hi witch dipstick do you have can you post a picture of the engine and dipstick, there are at least 4 different type of dipsticks used on K321 engines
#34 Siman OFFLINE
Siman
  • 37 Thanks
  • 43 posts
Posted February 13, 2018 - 04:26 PM
Engine plate
#35 Siman OFFLINE
Siman
  • 37 Thanks
  • 43 posts
Posted February 13, 2018 - 04:27 PM
Dip stick. Sorry it took so long
  • MNGB and Mark 149 J. have said thanks
#36 JBRamsey OFFLINE
JBRamsey
  • 1,568 Thanks
  • 878 posts
Posted February 13, 2018 - 06:20 PM
For your leaking fuel tank, mark the spots where it leaks, fill it with water and tig it. I presume it's leaking where the ends were welded on.
#37 MNGB OFFLINE
MNGB
  • 2,625 Thanks
  • 1,569 posts
Posted February 13, 2018 - 06:33 PM
Hi I have a dipstick like that will measure it tomorrow, got a question what is the height of the oil pan from base of engine mount to the split line where it bolts to the engine block? In the picture it almost looks like its a short pan but it just may be optical illusion
#38 Siman OFFLINE
Siman
  • 37 Thanks
  • 43 posts
Posted February 13, 2018 - 08:13 PM
I will check it to tommorow. Done got in my easy chair. The gas tank leaks at the petcock.
#39 shaeff OFFLINE
shaeff
  • 72 Thanks
  • 48 posts
Posted February 14, 2018 - 08:11 AM
Mine also leaked at the petcock, in my case it was just a matter of removing the old teflon tape that was mushy and mostly gone, clean the threads, put good quality tape back in place. No more leak.
#40 Siman OFFLINE
Siman
  • 37 Thanks
  • 43 posts
Posted February 14, 2018 - 08:18 AM
I want to find a good factory tank. Mine was swiss cheese when i purchased the tractor. Any have a good tank for sale? Let me know.
#41 MNGB OFFLINE
MNGB
  • 2,625 Thanks
  • 1,569 posts
Posted February 14, 2018 - 12:46 PM
Hi Siman, I measured the dipstick and from the length is 2.75" from the tip to the pipe plug the full mark is 1 1/16" from the pipe plug
#42 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 14, 2018 - 02:07 PM
I have the same engine K321S and I think someone changed your oil pan.  Here is a picture of mine. As you can tell it is much deeper which is probably why you can't get 2 quarts in your engine.
I am not sure what I would do with a smaller pan.  Maybe change my oil more frequently.  Maybe use 30 weight since it is a little heavier as the oil will run hotter with less of it.
PS
I wonder if your drive shaft is a little off due to the difference in engine height?
Edited by coxhaus, February 14, 2018 - 02:09 PM.
  • MNGB said thank you
#43 Siman OFFLINE
Siman
  • 37 Thanks
  • 43 posts
Posted February 14, 2018 - 03:38 PM
Looks like its 2 1/2 inches. Dip stick is 2 3/4 to the bottom of the plug
  • Mark 149 J. said thank you
#44 MNGB OFFLINE
MNGB
  • 2,625 Thanks
  • 1,569 posts
Posted February 14, 2018 - 06:27 PM
Hi that's the right oil pan and dipstick length I measured one this afternoon and the pan was 2.5" and the dipstick was 2.75" full mark is 1 1/16" from plug base, its got to hold 2 qts
Edited by MNGB, February 14, 2018 - 06:29 PM.
#45 Siman OFFLINE
Siman
  • 37 Thanks
  • 43 posts
Posted February 14, 2018 - 07:04 PM
Thanks guys.
