JD 4100 hydro 3 point won't lower
1 reply to this topic
#1 ffmedrn68 OFFLINE
ffmedrn68
  • 1 posts
Posted February 01, 2018 - 11:39 AM
Hello, I need some guidance on my JD 4100 hydro  The 3 point hitch will raise but it will not go down. I have replaced the fluids changed the filters with not results. I have also removed the rockshaft control value and didn't see anything on visual inspection ,but I did not take it apart. The 3 point did come down on its own when the  fluid was removed and I could raise/lower it by hand with ease. I have opened and closed the control value with no change and even tried adjusting the control value.  I am open to any help PLEASE !! Thanks.
#2 dropped82 ONLINE
dropped82
    Nut Case
  • 2,740 Thanks
  • 1,906 posts
Posted February 02, 2018 - 02:54 PM
Does it have hydraulic down pressure? Or does it lower by gravity? I'm not real familiar with those particular machines. If it has down pressure, you could have a hose collapsed that only collapses when the fluid goes a certain direction. Causing your issue.
Edited by dropped82, February 02, 2018 - 05:24 PM.
