Shaw R7A plow mounting frame info
8 replies to this topic
#1 hddlh ONLINE
hddlh
  • 45 Thanks
  • 78 posts
Posted February 01, 2018 - 09:20 AM
Can someone provide pictures of the mounting frame for a mold board plow for a R7A tractor?  I have the plow but no way to attach.  Thinking if I can get enough details I might be able to fabricate close to original, since it looks its' made from bar stock and plate.  Any help would be appreciated.
#2 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 406 Thanks
  • 131 posts
Posted February 01, 2018 - 02:36 PM
Moldboard Plow instruction sheet.
Cliff
  • hddlh said thank you
#3 hddlh ONLINE
hddlh
  • 45 Thanks
  • 78 posts
Posted February 01, 2018 - 05:36 PM
Thanks a lot that gets me off to a good start. That gives me a list of all the pieces. Hope someone has pictures to show more detail about how they look.
#4 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 406 Thanks
  • 131 posts
Posted February 01, 2018 - 08:30 PM
Which pieces are you missing?  Do you have 24" or 16" rear wheels?
Cliff
#5 hddlh ONLINE
hddlh
  • 45 Thanks
  • 78 posts
Posted February 02, 2018 - 08:20 AM
The tractor has 24" wheels.  I have cultivators for it, so I have items 1L and 1R.  Then I have items 4, 5, 10 and 12 off your listing.  The levers for raising and lower are also there.
#6 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 406 Thanks
  • 131 posts
Posted February 03, 2018 - 10:29 AM
Item 6 is 7/16 rod.  2L and 2R are made from 4 inch long tubes 1 5/16 OD with 1/8 wall thickness. Item 3 is made with 1 inch solid rods, 2 inch by 1/2 inch plate, and 2 1/2 X 1 X 3/16 angle iron.  The two 7/16 holes are 3/4 on center.  The holes in the 2 inch plate are 1/2 inch, 1 inch on centers.  A 1 inch ID collar is located above the 2L and 2R weldments, but is not identified in the picture.
Cliff
  • KennyP and hddlh have said thanks
#7 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 406 Thanks
  • 131 posts
Posted February 03, 2018 - 10:34 AM
Rest of pictures.
Cliff
#8 hddlh ONLINE
hddlh
  • 45 Thanks
  • 78 posts
Posted February 05, 2018 - 09:56 AM
Mr. Bridgford thank you for all the information you've provided, should be no problem fabricating what I need.  Your kind of help is what makes this hobby so much fun.  Hate to ask, but you wouldn't have picture of item 8, the lifting bracket on the back?
#9 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 406 Thanks
  • 131 posts
Posted February 06, 2018 - 04:55 PM
Rear lift hoop.
Cliff
