Need Front PK2414 Tractor Weight
19 replies to this topic
#1 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted January 30, 2018 - 01:27 PM
 I need some weight up front using my box blade.  I have been looking for front wheel weights for my PK2414 tractor.  They seem hard to find.  What are you using?
I was wondering if the little John Deere suitcase weights they sell at Home Depot for the garden tractors would fit on the front of a PK tractor?
  • chieffan said thank you
#2 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,793 Thanks
  • 5,093 posts
Posted January 30, 2018 - 06:39 PM
I run wheel weights on the inside and outside of the front wheels.
The factory bumper/weight rack is a nice heavy built unit,  but its mounts are NOT designed to carry much weight.
  • Alc, MNGB, chieffan and 1 other said thanks
#3 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,011 posts
Posted January 30, 2018 - 07:06 PM
First, that bumper out front is NOT a weight bracket and is only held on by two 3/8" bolts, one each side. Weights were put in wheels. The front wheels should be 12" and are same as on an IH Cub, not Cadet, but the bigger Cub. SO, weights for those are what most guys are using on the PK's. Two bolts holds them on easy. Not sure weight on those. Putting two on, not sure if room, but if others have done so, guess will work. The rears are also Cub wheels and can put same brand on there, OR, even the bigger ones off an A model will still bolt to those wheels.
#4 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 01, 2018 - 11:10 AM
I guess I am still looking for front wheel weights.
#5 MNGB ONLINE
MNGB
  • 2,619 Thanks
  • 1,568 posts
Posted February 01, 2018 - 02:01 PM
Here you go a bit spendy but the only ones on ebay, you could ballast the front tires with windsheild washer fluid.
https://www.ebay.com...MEAAOSw1DtXGi-9
  • KennyP and coxhaus have said thanks
#6 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 01, 2018 - 02:10 PM
Seems high priced.  What do they usually sell for?
#7 MNGB ONLINE
MNGB
  • 2,619 Thanks
  • 1,568 posts
Posted February 01, 2018 - 02:22 PM
Hi front wheel wts are never cheap I don't know what they sell for because  at what there priced I just never stop and look or deal. One thing to take in consideration on that deal is it includes free shipping which would be a good chuck of change
#8 KennyP ONLINE
  • 40,877 Thanks
  • 47,091 posts
Posted February 01, 2018 - 02:36 PM
That's probably why they are that expensive. Shipping could be nearly half that!
  • coxhaus said thank you
#9 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 01, 2018 - 04:10 PM
I am going to a tractor meet on Saturday.  Maybe I can save the shipping cost.
#10 Glenn Ayers ONLINE
Glenn Ayers
  • 63 Thanks
  • 86 posts
Posted February 02, 2018 - 07:41 PM
Most refer to them as "Farmall Cub" ... vs .. Cub Cadet
#11 countryboy88 OFFLINE
countryboy88
  • 105 Thanks
  • 146 posts
Posted February 02, 2018 - 10:51 PM
Another option is to build a weight bracket that mounts to the frame mounts. Here is mine. The bottom pic is after I modified it to mount a snow blade on it.
  • Alc and coxhaus have said thanks
#12 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 04, 2018 - 11:20 AM
Do these look like the right wheel weights for the front?
https://www.ebay.com...119.m1438.l2649
#13 MNGB ONLINE
MNGB
  • 2,619 Thanks
  • 1,568 posts
Posted February 04, 2018 - 11:29 AM
Hi those should work and not a bad price and shipping is really good.
#14 coxhaus OFFLINE
coxhaus
  • 136 Thanks
  • 146 posts
Posted February 04, 2018 - 11:43 AM
Thanks. I bought them.
  • KennyP and MNGB have said thanks
#15 MNGB ONLINE
MNGB
  • 2,619 Thanks
  • 1,568 posts
Posted February 04, 2018 - 11:52 AM
Sounds good coxhuas let us know how they work out
