Update on Bolens XL 1669L Drive Shaft Rebuild, repairs and Upgrades
31 replies to this topic
#16 KennyP ONLINE
  • 40,838 Thanks
  • 47,077 posts
Posted February 01, 2018 - 07:16 AM
Very nice shaft! Should out last the tractor!
  • boyscout862, bprzyw and logmillingman have said thanks
#17 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted February 01, 2018 - 09:03 AM
Thanks Mark,
I am glad I went with the new upgraded shaft, it is going to make this XL an even better performer. Coupled with the Vanguard engine this tractor will be a joy to use. I call it "smooth power," the next step is to install the new air shroud and new air filter assembly on the engine.
  • KennyP, boyscout862, bprzyw and 1 other said thanks
#18 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted February 01, 2018 - 09:12 AM
Thanks Tom,
I can't wait to get this XL all reassembled and fire it up and see how smooth it is. The engine had a lot of things wrong with it, the stator was bad one of the coils was out of adjustment and was to tight to the flywheel, the carb and intake were really dirty because it had been run without a filter on it even though it was only used in the winter to plow snow it still was really dirty.
I believe the vibration had broke the filter housing. It seemed like the engine was running on one cylinder, wiring was melted and the wire to shut off the engine was not connected so it was shutting off on the fuel solenoid.
So a little bit of a mess.
  • KennyP, boyscout862, TomLGT195 and 2 others have said thanks
#19 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted February 01, 2018 - 09:50 AM
Thanks KennyP for your comments and thank you for helping me edit the post to separate the pics with the text! This really help to make more sense to the explanation of the drive shaft!
See I told you guys KennyP is my go to tech guy!
I hope this post will be helpful for other guys that have this similar Drive shaft design.
Edited by logmillingman, February 01, 2018 - 10:27 AM.
#20 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted February 01, 2018 - 11:19 AM
Ok Guys now that the drive shaft is completed I can begin to talk about the other repairs and up grades I am doing with the XL 1669L.
One of the things that really drives me when I am working on a tractor is what did the tractor look like when it was new and how did it feel and sound when it was run and trying to recapture that in the rebuild. The other thing that I like to do is do upgrades on the tractor when I see a design problem. These things would be keeping with the spirit of the design or would have been something that was available either for the tractor or the component say like the engine, I try to keep everything original so it looks stock. So these items tend to be mechanical and part of the function of the tractor and not the esthetics. You will see an example of this in this post.
The first item that I am up grading is the air filter. I PM Husky about the air filter problem I was having a while ago and he said his XL's all had the round filter cartridge. The problem I have on my XL is that housing sticks out and bends metal fire wall out. Pics 5265 - 5263
So I found a square filter housing on e-bay from a 1989 Vanguard to replace the round filter. If you look in the manual it shows both filter types for the XL 1669 tractors and the parts manual actually shows this square filter in the diagram. Pics 6561 - 5662
The next thing is the air shroud for the engine,:
The vibration from the drive shaft broke out the bolts that mount the fire wall to the front of the engine. So I got a shroud from e-bay from the same guy I got the filter from. I asked him if he could send me the shroud fron the same engine that the filter came off of because the rubber air inlet boot between the filter and the engine is different. Pics 5657 - 5658 - 5659 - 5660
I really liked dealing with this guy from e-bay he sent all the tin for the engine and put all the nuts and bolts in a zip lock bag to mount everything. Also all the mounting hardware for the square filter because it is different then the round filter, and that hardware is no longer available from Briggs. Pics 5663 - 5664
Edited by KennyP, February 01, 2018 - 12:33 PM.
#21 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted February 05, 2018 - 01:59 PM
I finished painting the drive shaft this weekend and took it down to the power equipment place I work with. All the parts that I ordered from e-bay have come in, now that the drive shaft is complete the tractor will be re assembled later this week.
Here are some pictures of the painted drive shaft.
Edited by logmillingman, February 05, 2018 - 05:54 PM.
  • blackjackjakexxix, boyscout862, TomLGT195 and 4 others have said thanks
#22 Husky OFFLINE
Husky
  • 1,331 Thanks
  • 1,148 posts
Posted February 08, 2018 - 12:53 PM
You did a great job on getting that done. He really did a nice job. Lets hope it all goes together well for you.
  • bprzyw and logmillingman have said thanks
#23 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted February 15, 2018 - 04:06 PM
I wanted to give you guys an update; I just talked to Tom down at Devone Lane Power Equipment they reinstalled the engine with the new drive shaft.
Two problems came up: First, because the drive shaft is larger in diameter then the original the shaft it was rubbing against the steering gear.
Second, When they tried to start the engine there was no spark.
To fix the clearance problem they pulled the engine and flipped the engine mounts upside down to drop the engine chassis by 3/8" that provided the clearance necessary for the steering gear, that is fine because I only plow with this tractor.
The spark problem ended up being that some one had put aftermarket coils on the engine and there was no shut off wire so the engine was shutting off by the fuel solenoid, the wire harness was not correct it was missing the diodes in the wire harness. They put a pair of used Briggs coils on the engine along with the proper wire harness that they had in there used Briggs parts bin.
This tractor had a lot of problems that I did not know about when I purchased it, so I am glad I didn't pay a lot for it. I'm just glad I have been able to take care of all the problems.
Tom said that they started the engine on the bench once they had fixed everything properly and it ran really good, they were concerned that there might be other issues inside the motor, so that is good news. They set all the proper clearances on the coils and the valves.
Tom's comment is that this tractor has been a real pain in the neck working through all the things that people had done to it over the years that were not repaired correctly. I guess that happens sometimes, It will be a nice running machine when they are done with it.
  • boyscout862, TomLGT195, bprzyw and 4 others have said thanks
#24 Husky OFFLINE
Husky
  • 1,331 Thanks
  • 1,148 posts
Posted February 21, 2018 - 07:42 AM
Yes they tend to be worked on a lot over the years. Unfortunately your previous owner did not do things right. You will love to drive and mow with it. I loved mine for mowing it was great. The only reason I sold mine was the upgrade to the DGT 1700 for mowing. Best of luck with yours.
#25 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted April 20, 2018 - 10:15 PM
This evening I went down to Devone Lane Power Equipment and worked with the owner on replacing the steering wheel upper and lower shaft bushings on my 1669L Bolens tractor.
The lower bushing is a bronze oil lite, and the upper bushing is made of  nylon. I did not get all the pictures that I wanted but I got some.
The drag link was disconnected first and the steering gear was removed. The hydro filter was removed so the drive shaft could be disconnected from the hydro and moved over to the side.
The gas tank and battery was removed to access the bolt where the steering shaft goes through the frame. The steering wheel was removed to gain access to the upper bushing. There is a 1/4" roll pin that must be removed so the steering wheel can be removed. After the plastic steering wheel was removed the steel insert had to be heated and sprayed with PB Blaster. Finally after using a brass flat punch and a power steering puller we were able to separate the steering shaft from the steel steering wheel insert.
The steering shaft was removed and prepped for the new bushings. The nylon bushing was greased and installed in the top of the column, and the lower bushing was greased and slid onto the steering shaft and then over the shaft of the pinion gear. The steering shaft was then reinserted up from the bottom of the tractor through the top part of the dash board.
Anti seize was applied to the top of the steering shaft and the steering wheel steel insert was installed into the plastic steering wheel. The steering wheel was then installed onto the steering wheel shaft and the 1/4" roll pin was installed.
The steering gear was installed along with a new hydro filter, then the drive shaft was installed onto the hydro pump.  A new grease fitting had to be installed in the steering gear because it was plugged with old dried grease. It was then able to be greased.
Success! now with the new bushings installed the drive shaft no longer rubs against the pinion gear!
Edited by logmillingman, April 22, 2018 - 12:23 PM.
  • KennyP, Cat385B, boyscout862 and 5 others have said thanks
#26 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted April 23, 2018 - 04:03 PM
I took some pictures of the old bushings so you could see the condition of them when we took them out of the 1669L after 1000+ hours of operation.
The nylon bushing that was in the top of the steering column was worn egg shaped.
The lower bronze oil lite bushing was completely worn out to the point that there was no bronze bushing left except the flange of the bushing.
  • KennyP, boyscout862, TomLGT195 and 4 others have said thanks
#27 Husky OFFLINE
Husky
  • 1,331 Thanks
  • 1,148 posts
Posted May 02, 2018 - 09:57 AM
Man that's bad. It was not a great engineering effort on that bushing. Mine both were bad. I could not find one so I made one using a bushing from the hardware store. It worked ok but not nearly as nice as a new one would. My DGT1700 could use some help in that area now too. One project I have not looked into yet.
  • bprzyw, logmillingman and Clevis have said thanks
#28 logmillingman ONLINE
logmillingman
  • 861 Thanks
  • 415 posts
Posted May 07, 2018 - 07:21 PM
Well the 1669L went to the drive shaft shop today, there is a vibration in the drive line so Bruce at General Machine is going to tweak it.
  • Husky, KennyP, TomLGT195 and 2 others have said thanks
#29 Husky OFFLINE
Husky
  • 1,331 Thanks
  • 1,148 posts
Posted May 08, 2018 - 07:13 AM
That's a bummer. Hopefully he gets it back to you soon grass is growing!
#30 Doug E. ONLINE
Doug E.
  • 398 Thanks
  • 206 posts
Posted May 08, 2018 - 07:50 AM
Concerning bronze bearings, my preference is for bearings made of a leaded tin bearing bronze, such as SAE 660 bearing bronze.  IIrc, it is now called 932 bronze.
This alloy tolerates misalignment, intermittent lubrication, and foreign particles.  It does not gall or seize on the shaft, and is not abrasive as some sintered bearings can be.
The down side is if you can't find one available, you need access to a lathe to make one, or know someone who does that you can bribe to make it for you.  The bronze stock alone is more expensive than the oil lite bushings.  When I need to replace a bronze bushing on my equipment, this is what I use.  Fwiw.
The sintered oil lite bearings are hands down initially cheaper.  If you are keeping the equipment long term, I think the bearing bronze is cheaper over time.
Regards,
Doug
  • bprzyw, logmillingman and kjmweld have said thanks
