Anyone use or mess around with a forge?
27 replies to this topic
#16 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,299 Thanks
  • 9,779 posts
Posted January 29, 2018 - 08:20 AM
I also use a piece of a railroad track as a pounding and bending tool. Works great!!
Where are all these railroad track anvils missing from!
Edited by LilysDad, January 29, 2018 - 08:20 AM.
  • dropped82 and chieffan have said thanks
#17 SimplyRad OFFLINE
SimplyRad
  • 1,100 Thanks
  • 839 posts
Posted January 29, 2018 - 08:38 AM
Lump charcoal is available from Lowes.
https://www.lowes.co...arcoal/50330091
  • Alc, dropped82 and chieffan have said thanks
#18 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted January 29, 2018 - 08:42 AM
If you can find a track section  that was replaced because of wear it will be a little harden from use also there are different weights per yard so the bigger the better for homemade anvils  .
Edited by Alc, January 29, 2018 - 08:43 AM.
  • boyscout862, dropped82, Sawdust and 2 others have said thanks
#19 KennyP OFFLINE
  • 38,337 Thanks
  • 45,913 posts
Posted January 29, 2018 - 09:05 AM
I have 2 nice pieces of rail, one is a bigger size than the other. I can cut a piece and ship it, you pay shipping! LOL.
  • boyscout862, dropped82, Sawdust and 1 other said thanks
#20 MNGB ONLINE
MNGB
  • 2,126 Thanks
  • 1,408 posts
Posted January 29, 2018 - 02:10 PM
Hi well this morning I dusted of the carbon arc torch and played with it it worked ok with some practice it maybe a useful tool, question for Chris I watched your video (good video) and noted you set the welder ro 105 amps is this normal operating temp/amps or does the size of the carbon rods change the amp setting? I looked online but really could find any good information.
Will try it again this afternoon to see if I can improve my skills :(
  • KennyP, boyscout862, dropped82 and 2 others have said thanks
#21 MNGB ONLINE
MNGB
  • 2,126 Thanks
  • 1,408 posts
Posted January 29, 2018 - 07:26 PM
Hi all well this afternoon I tried the carbon arc torch for heating some flat steel 2" X 7/16" to bend and angle to build a "A" frame for a 3 pt tool bar, well it worked but its pitiful slow process it took approx 5 min to get it hot enough to bend I switched to the oxyacetylene torch and it heated the steel to bendable temps is approx 1 min. So yes it works but you must be patient but if you don't have a gas welding set up but do have a ac welder that is 220 VAC powered its an option here's a link to making your own torch
http://www.instructa...-volt-stick-we/
  • dropped82, Sawdust and chieffan have said thanks
#22 MNGB ONLINE
MNGB
  • 2,126 Thanks
  • 1,408 posts
Posted January 29, 2018 - 07:33 PM
Hi all, back to the original post question here are some pictures of the anvil I have and a picture of the forge, the forge is really back behind a lot of other stuff so I got within about 20' and used the tele-photo lens option to get a picture
  • Alc, KennyP, Cvans and 6 others have said thanks
#23 Cvans ONLINE
  • 6,648 Thanks
  • 6,129 posts
Posted January 29, 2018 - 11:04 PM
Hi, sorry for not replying sooner, been outside all day.
First and most of all that is not my video. Donnyboy73 deserves the credit. He did a nice job and that happens to be the same torch I have.
Yes the larger the carbons the more heat you can run. If you think about it 100 amps run an 1/8" welding rod and would take quite a while to heat the iron you used. Most of the time I'm not heating large iron.
At first 5 minutes might seem like a long time but if you consider how long it would take to heat a forge to make a couple of bends the 5 minutes doesn't seem that long. I think you will find that running your welder at a 100 amps is less costly than running a rosebud on a torch.
Also you could purchase quite a few old buzz box welders for the cost of a set of tanks not to mention comparing a gas torch set against a carbon arc torch.
Yes I'm trading time for money but being retired I have the time. On top of that it is kind of fun to do things the old way and the Grand-kids get a kick out of it.
#24 gopher OFFLINE
gopher
  • 763 Thanks
  • 757 posts
Posted January 29, 2018 - 11:48 PM
Or you can use 2 piece torch tip and burn cheaper propane gas.
  • Cvans, boyscout862, dropped82 and 4 others have said thanks
#25 boyscout862 ONLINE
  • 12,850 Thanks
  • 9,171 posts
Posted January 31, 2018 - 08:12 AM
attachicon.gifHPIM1754.JPGattachicon.gifHPIM1755.JPGattachicon.gifHPIM1756.JPGattachicon.gifHPIM1757.JPGattachicon.gifHPIM1758.JPG
That is a really nice forge. Take the time to clean it up and service the blower gears before using it. Good Luck, Rick
  • Cvans, dropped82, MNGB and 2 others have said thanks
#26 Sawdust ONLINE
Sawdust
  • 5,657 Thanks
  • 3,370 posts
Posted February 06, 2018 - 07:45 PM
Nice score on the forge. I have a piece of anvil also works great. I need to mount it on a stump, now I just drag it around on the floor. I'm thinking about carving on it to give it a real look of an anvil. They got some nice ones on YouTube.
I've been wanting to build a forge too but waiting to get a large truck brake drum. I have a water pump tank that is very thick that could be cut in half & would make a good pot. I'm thinking to set the brake drum in the middle of it. The area for the coal doesn't have to be that large just a good size pot around it so you can feed the coal as needed. Again go on YouTube there's dozens of home made forges on there.
  • boyscout862, MNGB and chieffan have said thanks
#27 chieffan OFFLINE
  • 10,135 Thanks
  • 6,632 posts
Posted February 09, 2018 - 11:31 AM
I had thought about building/buying a forge.  Most of my projects don't require a lot of bends so the time to heat the forge would be a big negative for me.  The two tanks for my Oxy/acetylene are going on their third year so the cost is not a big factor for me.  Beside I like the quickness of the torch.
  • boyscout862, Sawdust and MNGB have said thanks
#28 MNGB ONLINE
MNGB
  • 2,126 Thanks
  • 1,408 posts
Posted February 09, 2018 - 12:56 PM
Hi chieffan, like wise I like the quickness and ease of use with a torch just out of curiosity do you know how much a tank of acetylene  is in your part of the country last I bought here in WC MN it was about $90.00 that was a couple of years ago this past fall I needed oxygen and it was $101.78 these are large tanks.
  • Cvans and boyscout862 have said thanks
