Cub 123 Transaxle removal
cub 123 transaxle removal
25 replies to this topic
#1 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,692 Thanks
  • 1,510 posts
Posted January 28, 2018 - 12:37 AM
I bought this 123 for my son about a year ago.  We got it running back in the summer but notice that the transaxle has 2 broken bolt where it bolts to the frame.  The internal brake plunger is also stuck so the brakes don't work.  The only way to really solve the problems is to pull out the transaxle.  I wanted my son to do most of the work of dissemble so I sat in my chair and only helped when he asked.  We're ready to pull it out but we ran out of time tonight so we'll finish it up tomorrow.
20180127_153313.jpg 20180127_153320.jpg 20180127_153329.jpg 20180127_164941.jpg 20180127_165048.jpg 20180127_170224.jpg 20180127_172044.jpg 20180127_173607.jpg 20180127_173641.jpg 20180127_173757.jpg 20180127_173746.jpg 20180127_194128.jpg 20180127_194123.jpg
Someone really expected to haul a lot of heavy stuff with this hitch!
Edited by Mark 149 J., January 28, 2018 - 12:38 AM.
  • Alc, KennyP, boyscout862 and 3 others have said thanks
#2 boyscout862 ONLINE
  • 13,440 Thanks
  • 9,385 posts
Posted January 28, 2018 - 07:57 AM
Good for you both. He is learning and building real self confidence. While you have it apart, are you going to paint it? Good Luck, Rick
  • Mark 149 J. said thank you
#3 chieffan ONLINE
  • 10,901 Thanks
  • 6,923 posts
Posted January 28, 2018 - 09:59 AM
Some of the Cubs were pron to breaking off those bolts.  Their is a brace that can be bolted to the rear end axle housing bolts with an arm back up to the frame to help with the torque on those 4 bolts.  Little pricey but I made mine for a super cub I sold.  Well worth the time spent to build them while you have it apart.  Good project for the boy - he will learn more doing that than a week at school. Have fun.
  • KennyP, boyscout862 and Mark 149 J. have said thanks
#4 EricR OFFLINE
EricR
  • 709 Thanks
  • 427 posts
Posted January 28, 2018 - 10:09 AM
Nice, I love to work on the old narrow frames, my dad and I have been doing it for around 40 years!!!
  • boyscout862 and Mark 149 J. have said thanks
#5 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,692 Thanks
  • 1,510 posts
Posted January 28, 2018 - 11:51 AM
Not sure yet.  Haven't really talked about painting it.
#6 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,692 Thanks
  • 1,510 posts
Posted January 28, 2018 - 11:54 AM
I didn't know that the older cub had a problem with breaking their bolts.  I had heard about the Supercubs breaking them.  I'll have to look into that further.  Do you have pictures of the bracket that you made?
#7 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,692 Thanks
  • 1,510 posts
Posted January 28, 2018 - 12:03 PM
This is our first narrow frame so I'm still learning how their different from my 149.  I wish they had a tunnel cover like the 149!  It's a lot more difficult to get to the linkages and drive shaft without it!
I hope to have that much time with my son as well!  I hope I will have enough patience!  My son is going through a phase of telling me that I'm "wrong" or "that's not right" and other things that can really try my patience!!!!
Do you have any suggestion or tricks when working on these narrow frames?
I know I could use your guidance on the internal brake that is stuck.
Thanks Eric!
#8 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,692 Thanks
  • 1,510 posts
Posted January 30, 2018 - 12:27 AM
My son and I were able to remove the transaxle tonight.  It came out fairly easy.  I think the transaxle is heavier then the engine for these tractors.  It gave me a good workout lifting it onto the workbench!
We removed the rear end cover to drain all of the fluid out and I was surprised by the bright red colored fluid that ran out. It almost reminded me of blood.  I don't know what kind of fluid it was but it did not look like the Hytrans fluid that I put in my cub 149 last summer.  Besides the red color it also seemed like it was a lot less thicker then the Hytrans.  I will have to compare the fluids tomorrow.  I removed the c-clip from the left axle.  Removed the axle and then removed the axle housing.  One of the broken off bolts is barely sticking out of the rear end housing and the other bolt is broken below the surface of the housing.  I will be trying to drill out the center and remove them with a bolt extractor.
If you know anything about the red fluid such as who makes it or if it can be used in the cub hydro please let me know.
20180129_200245.jpg 20180129_200316.jpg 20180129_200228.jpg 20180129_201707.jpg 20180129_201944.jpg 20180129_203925.jpg 20180129_203921.jpg 20180129_203912.jpg 20180129_203906.jpg
Beside fixing the broken bolts we will also be replace the rag joint (at the rear of the driveshaft), driveshaft pin, and possibly the driveshaft.
#9 dodge trucker ONLINE
dodge trucker
  • 2,684 Thanks
  • 3,336 posts
Posted January 30, 2018 - 07:13 AM
looks like that fluid had a bit of water in it.....
#10 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,692 Thanks
  • 1,510 posts
Posted January 30, 2018 - 10:25 AM
Yep!  Before we bought the tractor it had been sitting in PO shop for over 10 years.  The previous own before that had it sitting for a long time as well.  Have you ever seen fluid this red before?
#11 dodge trucker ONLINE
dodge trucker
  • 2,684 Thanks
  • 3,336 posts
Posted January 30, 2018 - 01:24 PM
Yeah it looks like plain old auto trans fluid....
#12 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,692 Thanks
  • 1,510 posts
Posted January 30, 2018 - 02:25 PM
Initially I thought it was ATF.  I've just never seen fluid this red.  The viscosity seems to be thicker as well.  I have some ATF at home that I will compare it too.  I hope that doesn't hurt the hydro pump.
#13 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted January 30, 2018 - 03:25 PM
It might be a mix!
#14 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,692 Thanks
  • 1,510 posts
Posted January 30, 2018 - 04:03 PM
It might be a mix!
That makes sense!  Do you think it hurt the hydro?  The hytrans is very thick compare to the fluid that I removed.  Might have to just wait and see.  I'll look more closely at the gears and bearings to see if there is any visible damage.  I don't want to dig into this any further then I have to.  I'll make sure and clean out as much of the old fluid as I can.
#15 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted January 30, 2018 - 04:46 PM
If it was still working, you are probably okay.
Also tagged with one or more of these keywords: cub, 123, transaxle, removal
