John Deere 455 running slower?
7 replies to this topic
#1 JD455noob OFFLINE
JD455noob
  • 1 Thanks
  • 5 posts
Posted January 26, 2018 - 09:39 PM
Does anyone know why a 455 would seem to run slower than normal during normal operating with no pto? It starts fine, seems to still have all the power. I had it in the shop a few weeks ago for a bad thermostat and a leak in the transaxle and when I got it back it seems that it doesn’t move as fast as it did. It’ll accelerate quickly and then slow down to a consistent speed. any ideas?
  • chieffan said thank you
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 27, 2018 - 11:37 AM
I would check the hydro linkage. There could be some slack somewhere, wear or binding perhaps. There is also a damper that can cause troubles if it wears out. The parts diagrams should be on jdparts.com.
#3 chieffan OFFLINE
  • 10,088 Thanks
  • 6,612 posts
Posted January 27, 2018 - 12:13 PM
Not to be a smart A - -  but I move that way all the time any more.  Start out quick and then down to half speed or less.
  • jms180, hdg4400, Leonard VanCamp and 1 other said thanks
#4 jms180 OFFLINE
jms180
  • 1,504 Thanks
  • 1,562 posts
Posted January 27, 2018 - 04:26 PM
Me also only can go in low gear  :rocker2:
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,965 Thanks
  • 9,997 posts
Posted January 27, 2018 - 05:54 PM
How's the transmission fluid level? Was it purged after it was opened up to fix the leak?
  • Mark 149 J. said thank you
#6 JD455noob OFFLINE
JD455noob
  • 1 Thanks
  • 5 posts
Posted January 27, 2018 - 06:12 PM
The fluid level is good, I’m gonna say it probably wasn’t purged. Would that cause it to move slower?
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,965 Thanks
  • 9,997 posts
Posted January 27, 2018 - 08:09 PM
Only initially, the system will purge any air in it after a max of a few minutes of run time.
#8 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,435 Thanks
  • 5,757 posts
Posted January 27, 2018 - 08:45 PM
Yes-  The hydro would be noisy (Pump)  Start the tractor and engages the tranny bypass lever behind the RR wheel.  It will purge air out of the pump.motor..  Just don't do it for a long time as the fluid will heat up and bad things happen after that..
What type of fluid did you put back in the tranny??
Pull the seat pan and inspect the linkage for wear and adjust/replace as needed..
Next is a pressure test on the pump if not any problem or improvement..
All I got for now..
