Kohler Command 18 project
ch18s spec 62510
16 replies to this topic
#1 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 25, 2018 - 04:38 PM
I picked this Command 18 up before Christmas as part of package deal with a Vanguard 16 that I wanted for my JD 318 repower project. Seller said same price of $30 for both so I grabbed the Command while I was there. It was on a Grasshopper mower but I forget why it was removed. When I got it home I pulled the plugs and tried to turn it by hand but did not have any luck. Now that I got the Vanguard 16 apart and pronounced dead I took a look at the Command today. A bit of disassembly yielded a couple of surprises...
Edited by Trav1s, January 25, 2018 - 04:43 PM.
  • Bolens 1000, jhn9840, KennyP and 2 others have said thanks
#2 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 25, 2018 - 04:39 PM
Once I removed the blower housing and the flywheel, the flywheel key was broken.
Edited by Trav1s, January 25, 2018 - 04:46 PM.
  • Bolens 1000, jhn9840, lyall and 3 others have said thanks
#3 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 25, 2018 - 04:49 PM
With the flywheel removed and the valve covers off, I dropped a screwdriver into the spark plug hole and turned the engine over by grabbing the output side of the crank.  Both pistons move, the valves open, and the crank spins very smoothy.  I may get lucky on this one...
  • KennyP, boyscout862, EricR and 3 others have said thanks
#4 Billy M OFFLINE
Billy M
  • 743 Thanks
  • 584 posts
Posted January 25, 2018 - 04:53 PM
Hopefully, that is all that was wrong with it!  Don't forget to put new head gaskets and oil seals in it while you have it apart.  The Commands like to go through those.
  • Bolens 1000, Trav1s, boyscout862 and 1 other said thanks
#5 Bolens 1000 ONLINE
  • 15,549 Thanks
  • 18,317 posts
Posted January 25, 2018 - 04:58 PM
Looks like you may be able to save her!
the most common items I go through for sales of these is valve gaskets/parts, oil seals and cylinder head gasket's other than that they really dont break all that often
#6 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 25, 2018 - 05:03 PM
That is good to know.  I will keep that in mind as this project unfolds.  Now the question is... If it is good, where might I put it?
#7 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 25, 2018 - 05:45 PM
I wonder if the flywheel side crank seal is bad on this one due to the large amounts of oil on that side of the block.
  • boyscout862 and Mark 149 J. have said thanks
#8 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted January 25, 2018 - 06:02 PM
While you have it apart I would replace the seal.
To be on the safe side.  Better now than later.
#9 KennyP OFFLINE
  • 41,453 Thanks
  • 47,382 posts
Posted January 25, 2018 - 06:07 PM
Id replace it! That's a bunch of oil in there!
#10 dodge trucker ONLINE
dodge trucker
  • 2,901 Thanks
  • 3,523 posts
Posted January 25, 2018 - 07:48 PM
Some people have all the luck.....we can't even find a horizontal Kohler twin around here.., opposed or v style hope it works out for you now you need another tractor to put it onto....
#11 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,905 Thanks
  • 1,616 posts
Posted January 25, 2018 - 08:30 PM
1 out of 2 is not bad for $30!
Glad everything else seems to be in order.
  • boyscout862 and dodge trucker have said thanks
#12 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 25, 2018 - 10:31 PM
I have one that has been offered to me...
It is the right color and it is close.
Edited by Trav1s, January 25, 2018 - 10:56 PM.
  • Mark 149 J. said thank you
#13 dodge trucker ONLINE
dodge trucker
  • 2,901 Thanks
  • 3,523 posts
Posted January 26, 2018 - 01:19 PM
Well go get it before they change their minds
#14 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 26, 2018 - 03:04 PM
I watched the Vanguard 16 pop up on CL multiple times between July and when I picked it up.  Price stayed the same but this Command was added when the ad showed up in November.  I tried to get out there before thanksgiving but ran out of time.  In the case of luck, I know this is incredible luck.  Seller told me people wanted him to drive all over the state to meet up and thought the price was too high.  The new starter on the Vanguard and parts potential made it worth the trip for me.  This Command 18 is like winning the lottery. I just wish it was easier to move around.  Beggars can't be choosers...
  • dodge trucker and Mark 149 J. have said thanks
#15 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted February 02, 2018 - 04:23 PM
Measured the crank and it is 1 1/8"
