No Lift Today
24 replies to this topic
#1 coxhaus OFFLINE
coxhaus
  • 122 Thanks
  • 141 posts
Posted January 23, 2018 - 05:26 PM
I went out to practice with my box blade again today after not doing a great job yesterday and I have no lift in my hydraulic's today.  I can turn the hydraulic pump by hand so I am thinking it is a lose belt.  It kind of looks like you adjust it like an alternator where it has a pivot point.  It looks like you loosen a nut on the right side and pivot on the left.  Does this seem correct?
The belt has a little orange on it so I am thinking it is the original belt.  Is it possible the belt has stretched too much?  Does anybody know what size the belt is?  Is it easy to replace?
Edited by coxhaus, January 23, 2018 - 06:18 PM.
#2 todapuckett OFFLINE
todapuckett
  • 23 Thanks
  • 37 posts
Posted January 23, 2018 - 09:23 PM
Yes, you adjust it like an alternator.  It is not an easy fix to replace it, you have to disconnect the engine from the drive-shaft.  I am hoping someone else will have some info on the best way to replace it as mine is in need or replacement too
  • coxhaus said thank you
#3 James Bosma ONLINE
James Bosma
  • 1,334 Thanks
  • 657 posts
Posted January 24, 2018 - 12:31 PM
Sounds like you know how to adjust the belt, may have to loosen pivot bolt too
Not sure on your setup as to how the hydraulic pump is driven, pictures would help.
Sounds like you have to remove the driveshaft to replace, don't think there be a way around it unless you use this style of belt
  • coxhaus and bazil.w.duke have said thanks
#4 glgrumpy OFFLINE
  • 8,617 Thanks
  • 7,923 posts
Posted January 24, 2018 - 01:38 PM
Yes, split tractor at bellhousing after removing all the front tins, loosening engine, etc. If you do this, put an extra belt in housing, kinda zip tie it in to hold, in case it happens again. Most just get the adjustable belt shown above, they seem to be durable and no teardown do replace then. Might have to keep an eye on the tension on a new one for awhile too. You sure the pulley isn't just loose on the shaft and slipping?  Sheared key and or a set screw?
#5 coxhaus OFFLINE
coxhaus
  • 122 Thanks
  • 141 posts
Posted January 24, 2018 - 04:19 PM
I think the belt needs to be changed.  The belt has stretched too much. Here are the pictures.
  • olcowhand, Cvans and Mark 149 J. have said thanks
#6 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,390 Thanks
  • 1,348 posts
Posted January 24, 2018 - 04:28 PM
Yep!  Time to replace the  belt!
#7 olcowhand ONLINE
  • 41,230 Thanks
  • 31,439 posts
Posted January 24, 2018 - 04:43 PM
A belt like James posted about should do nicely and MUCH easier to put on if that drive shaft has to come out.  They come in different names, but HERE is an Ebay link to some.  They are strong and we used one for years on a combine to drive a hydraulic pump larger than yours where putting a normal belt would have required extensive work.
  • Mark 149 J. and coxhaus have said thanks
#8 coxhaus OFFLINE
coxhaus
  • 122 Thanks
  • 141 posts
Posted January 24, 2018 - 05:02 PM
There is a Harbor Freight close to me which sells link belts.  I have a link belt on my old drill press.  I did not know how much horsepower they would take but if it can run a bigger pump on a combine then I should be good to go.   I will try to pick one up tonight.
  • olcowhand and Mark 149 J. have said thanks
#9 coxhaus OFFLINE
coxhaus
  • 122 Thanks
  • 141 posts
Posted January 25, 2018 - 03:33 PM
I have the link belt on and it seems to work.
  • olcowhand, Alc and Mark 149 J. have said thanks
#10 coxhaus OFFLINE
coxhaus
  • 122 Thanks
  • 141 posts
Posted January 25, 2018 - 04:03 PM
I think I have problem. The belt and hydraulic pump pulley turns when running.  I used the box blade for 30 minutes. The box blade does not raise as high now and when I use the hydraulics the belt and pump pulley stop turning.  I am thinking the link belt stretched and it is slipping on the motor side.  Damn am I going to have to take a link out?
  • olcowhand said thank you
#11 coxhaus OFFLINE
coxhaus
  • 122 Thanks
  • 141 posts
Posted January 25, 2018 - 05:28 PM
I took a link out of the link belt.  The hydraulics work again.  There is no stopping of the pump and belt.  I probably should have taken 2 links out cause I am now at max adjustment again.  It sure is tight working on the link belt now.  I will have to see how much more it will stretch. Any more and another link will need to come out.
#12 olcowhand ONLINE
  • 41,230 Thanks
  • 31,439 posts
Posted January 25, 2018 - 06:02 PM
These belts do have to "settle in" a bit, so it may take a few adjustments till it finally gets settled nicely.
  • Cvans, Mark 149 J. and coxhaus have said thanks
#13 Cvans ONLINE
  • 6,659 Thanks
  • 6,133 posts
Posted January 26, 2018 - 01:57 AM
That should be an excellent place to use the link belt. Once the belt seats to the pulleys you should be good to go for a long time.
I've had excellent service with the one I'm running .
#14 coxhaus OFFLINE
coxhaus
  • 122 Thanks
  • 141 posts
Posted January 26, 2018 - 05:26 PM
I just figured out if I try raise the rear end of the tractor the belt slips.  It raises the box blade up and down fine.  If the box blade is all the way down on the cement and I try to lower the hydraulics more to raise the rear end the link belt slips because it stops turning.  Is this a feature of the link belt or do I need to tighten it up more? Should I be able to raise the rear end of the tractor using the hydraulics?
Edited by coxhaus, January 26, 2018 - 05:27 PM.
#15 olcowhand ONLINE
  • 41,230 Thanks
  • 31,439 posts
Posted January 26, 2018 - 06:46 PM
I'd say the belt needs a bit more tension yet.  Your pressure bypass should kick in before the belt would slip.  So when the original belt was still good, it would raise the tractor?
