SS16 Twin return spring help
ss16 clutch spring
16 replies to this topic
#16 twofitu OFFLINE
twofitu
  • 12 Thanks
  • 15 posts
Posted January 27, 2018 - 07:24 PM
FYI That SS16 won’t have any trouble with that plow. I plowed still ground in High 2nd gear, check out the video I put up. Sharpen and polish the plow, get the suck set and have someone walk behind you to tell you what’s going on. You’ll have a blast.
  • Bellevillerod said thank you
#17 Bellevillerod OFFLINE
Bellevillerod
  • 8 Thanks
  • 10 posts
Posted February 03, 2018 - 04:55 PM
Just an update, job took all of 15 min to complete. Did not have to remove belt, was able to remove battery and drop idler pulley down in its slot. pulled the foot pedal back attach spring to cotter pin. Took a ratchet strap and hooked to brake/clutch pedal then to plow blade. compressed brake and tightened strap. went back and lifted idler pulley back into position and tighten down. Removed strap and tractor was ready to go. Oh and the brakes were just not adjusted correctly did that and rear tires lock up and parking brake works fine. Thanks for the help and advise, starting on the other tractor now, it appears that I have a 1974 tractor with a 1977 engine in it.
  • KennyP and TAHOE have said thanks
