K361 carburetor advice
37 replies to this topic
#31 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 23, 2018 - 04:13 PM
  • LilysDad and classic have said thanks
#32 classic ONLINE
classic
  • 5,631 Thanks
  • 2,345 posts
Posted January 23, 2018 - 06:21 PM
Did you measure the length of the threaded linkages rod that connect the throttle shaft to the governor lever? There is a setting for that in the manual. You'll get this figured out, so have patients. Walk away from it for a bit, and have the boy hide any hammers that you own.
#33 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,125 Thanks
  • 10,198 posts
Posted January 23, 2018 - 06:39 PM
What your saying is that the spring determines the RPM. In reference to my post #24, the spring setting is supposed to adjust the sensitivity of the governor. If it isn't adjusted properly the engine will surge at open throttle. The RPM is adjusted by the throttle cable which isn't shown in the last drawing.
#34 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 24, 2018 - 07:53 AM
Yes the linkage is exactly right 2 and 7/8 I'm going to walk away from it for a while think about it can be done it again this weekend I'm so close to it being perfect but it still Lopes a little bit and it drives me crazy
  • classic said thank you
#35 shorty ONLINE
shorty
  • 5,836 Thanks
  • 5,417 posts
Posted January 25, 2018 - 04:56 AM
Is there any play in the govenor to carb linkage? I was trying to tune up a smaller Kohler and that was half of the trouble. A small spring to keep it from bouncing solved it.
#36 Beef OFFLINE
Beef
  • 45 Thanks
  • 50 posts
Posted January 25, 2018 - 11:16 AM
Want a throttle bushing, I have 5 spares. I'll send you one .  Believe me I went through the same thing .It will drive you NUTS!!!!!.
#37 Beef OFFLINE
Beef
  • 45 Thanks
  • 50 posts
Posted January 25, 2018 - 12:12 PM
Hi Beef, adding an "O" will not work it adds to much drag  BTDT doesn't but your right on its the carb NOT the Governor
The bushing size needed is 1/4" X 3/8" X 1/2"
Yea, I thought about that. Thanks.
#38 DH1 ONLINE
DH1
    Electric Tractors
  • 5,431 Thanks
  • 5,617 posts
Posted January 25, 2018 - 01:46 PM
How long is the engine running for? Is it warmed up? Have you adjusted the mixture screw's, both of them.
Lots of variable's for a surging engine
