K361 carburetor advice
37 replies to this topic
#16 MNGB ONLINE
MNGB
  • 2,132 Thanks
  • 1,413 posts
Posted January 21, 2018 - 08:38 PM
HI I'm sure you have the right carbs, did you check the original for wear? did you try adjusting the main jet?
#17 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 21, 2018 - 10:02 PM
something interesting about the gov.... when you watch vids of people setting the gov.  They first make sure the throttle plate is wide open then losten nut and rotate shaft.  There is simply no way to do this on my 361.  the linkage spring will not let the plate open wide
#18 Beef OFFLINE
Beef
  • 44 Thanks
  • 50 posts
Posted January 21, 2018 - 10:18 PM
That throttle bushing will drive you nuts,  I had the same problem it was the BUSHING, Check you tube to see how to change it.
I bought a new carb  from Kohler and it did the same thing. If I pull mine apart again I'm going to add a very small O ring between the bushing and the top of the shaft, grease it well and see what that does.
  • MNGB said thank you
#19 MNGB ONLINE
MNGB
  • 2,132 Thanks
  • 1,413 posts
Posted January 21, 2018 - 10:32 PM
Hi Beef, adding an "O" will not work it adds to much drag  BTDT doesn't but your right on its the carb NOT the Governor
The bushing size needed is 1/4" X 3/8" X 1/2"
#20 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted January 22, 2018 - 07:45 AM
Brian Miller sells bushings.
#21 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 22, 2018 - 01:25 PM
Here is a short video of the governor and again I'm a extreme novice at this so please excuse my ignorance if it's blatantly obvious to others what the problem is just trying to figure this out
#22 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 22, 2018 - 01:27 PM
Also I see the spring is touching the rubber hose it is not touching it after I moved it away it still did not alter the function
#23 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted January 22, 2018 - 05:26 PM
Did you do the initial governor adjustment?
#24 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted January 22, 2018 - 06:13 PM
I was just looking through the K361 manual concerning the governor. On chpt4, page 13 it talks about governor sensitivity. The spring is supposed to be in the third hole from the bottom of the governor arm and the second hole from the top of the throttle arm. Does that check?
#25 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 22, 2018 - 07:18 PM
by the way that higher rpm was the second click on the throttle
#26 Beef OFFLINE
Beef
  • 44 Thanks
  • 50 posts
Posted January 23, 2018 - 12:54 AM
Yes something is wrong, I ran one above the max rpm and threw a rod. Mine goes up in speed as you move the throttle up .
#27 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted January 23, 2018 - 10:34 AM
Did you do this adjustment?
#28 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 23, 2018 - 12:15 PM
Yes I did DH one but when you pull the arm all the way over it does not open the throttle all the way in or anywhere near it
#29 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
The spring is in a way that only allows a throttle to open about one-fifth of the way
#30 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted January 23, 2018 - 12:22 PM
Disconnect the spring, then do the adjustment.
The spring opens the throttle, the more tension the harder it pulls to open the throttle
The governor arm closes the throttle, the higher the rpm the harder it pushes to close the throttle
2 forces working in opposite directions set the rpm's
Edited by DH1, January 23, 2018 - 12:23 PM.
