Vanguard V-Twin 16HP - cl find
vanguard briggs v-twin
20 replies to this topic
#1 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 06:19 PM
Before Christmas I picked up a Vanguard V-twin 16 on Craigslist to use as part of my 318 repower. The newer starter alone made it worth the money that the seller wanted for the two engine deal. Seller said it lost power and then was removed from Grasshopper mower but not sure what happened. I gave the cash, loaded the stash, and hit the road with a grin on my face.
Model - 303447
Type - 0454-01
Code - 9403081
1" x 3" crank
Electric start
Edited by Trav1s, January 20, 2018 - 07:28 PM.
  • Mark 149 J. said thank you
#2 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 06:23 PM
Pics as I got it
#3 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 06:31 PM
When I got it home I popped the valve covers and the valves were moving when I turned the crank so I guessed a broken rod. Dropping a screwdriver into the combustion chamber on one side confirmed my guess.  Piston on one bank moves up and down but the other side did not.  My money was on a busted rod...
Edited by Trav1s, January 20, 2018 - 07:24 PM.
  • boyscout862, TomLGT195 and Mark 149 J. have said thanks
#4 jms180 ONLINE
jms180
  • 1,790 Thanks
  • 1,696 posts
Posted January 20, 2018 - 06:35 PM
that is a very good engine hope you can get it going
edit
well you have some parts
Edited by jms180, January 20, 2018 - 06:40 PM.
#5 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 06:46 PM
When I got it home, I noticed it had a more complete cooling shroud than the 20HP I am using in the 318 so I will clean, paint, and install them on the 20.  When I saw the ad, there are the parts I really wanted.  The starter that was used for less than one mowing season made it worth the trip.
Edited by Trav1s, January 20, 2018 - 07:21 PM.
#6 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,905 Thanks
  • 1,616 posts
Posted January 20, 2018 - 07:11 PM
Looks like a nice score.  Even if the engines aren't salvageable you now have plenty of cheap parts to work with.
#7 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 07:22 PM
Looking things over, I think I could easily clear a $125-150 by selling parts off of it.  I gave $30 for the pair and drove an hour to pick them up.
Wait for the next round of pics and the scoop on what I found today. :smilewink:
Edited by Trav1s, January 20, 2018 - 07:23 PM.
#8 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 07:33 PM
hTemps hit 40 outside so I grabbed some garage time. Removed the heads to get to the pistons. The one that did NOT move when you turn the crank is free in the bore. Removed the pto side of the engine to access the internals and found...
- one broken rod (no surprise)
- broken tooth on camshaft which lead me to...
- one broken camshaft (two places) with the end still stuck in the block :camera:
- lots of shrapnel in the oil pan
Edited by Trav1s, January 20, 2018 - 07:45 PM.
  • KennyP, boyscout862, Leonard VanCamp and 2 others have said thanks
#9 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,905 Thanks
  • 1,616 posts
Posted January 20, 2018 - 07:41 PM
ouch!
#10 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 07:43 PM
ouch!
Yeah!
#11 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 07:46 PM
Replacement used cam $30 + shipping
https://www.ebay.com...qwAAOSwehZaP-0V
Just wondering what the crank and bores look like.
Edited by Trav1s, January 20, 2018 - 07:49 PM.
#12 tractorskipper OFFLINE
tractorskipper
  • 654 Thanks
  • 395 posts
Posted January 20, 2018 - 09:02 PM
No doubt it lost power!  Probably also made a lot of noise that he failed to mention I guess.
#13 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 20, 2018 - 09:45 PM
I did not inquire as I wanted the parts and really did not care what I found inside.  I hoped it was something simple but this was planned to be a organ donor since I picked it up.  I feel a bit like a coroner doing an autopsy...
  • KennyP, dodge trucker and SupplySergeant have said thanks
#14 Trav1s ONLINE
Trav1s
  • 3,643 Thanks
  • 4,598 posts
Posted January 21, 2018 - 08:46 AM
At this point I think I am going to keep the good parts for my 20HP and sell/scrap the rest.  Digging around eBay last I think I can easily make $150 on it.
$20 for the good piston if not damaged
$50-75 for the carb (pretty sure it is different than the 20 I have)
$10 intake manifold
$50 crank (if it is good)
$10 oil pump (Don't know if it would sell)
$10 oil filter housing mount
$20 block
$25 flywheel
My keep list
$50 ($25 per side) heads (likely will keep them)
$20 for the blower housing and related shrouds
$25 front of engine case
Edited by Trav1s, January 21, 2018 - 08:46 AM.
#15 dodge trucker ONLINE
dodge trucker
  • 2,901 Thanks
  • 3,523 posts
Posted January 21, 2018 - 10:14 AM
Didn't you get 2 engines with this deal? what's with the other?
Also tagged with one or more of these keywords: vanguard, briggs, v-twin
