Case 224 Ignition Switch Wiring Help Please
case 224 ignition switch
3 replies to this topic
#1 jpswift1 OFFLINE
jpswift1
  • 794 Thanks
  • 617 posts
Posted January 18, 2018 - 01:13 AM
I'm rewiring my Case 224 that I'm rebuilding and I got all new electrical components so I don't have any issues in the future (I got an original equipment Case/Ingersoll ignition switch).  I'm building a brand new wiring harness and I was wondering if anyone knows what wire goes where on the ignition switch.  This is for a 1976 Case with a Kohler with the starter/generator unit and points ignition.
Here's a picture of the switch.  If anyone could help me, I'd really appreciate it.  Thanks in advance!
Edited by jpswift1, January 18, 2018 - 01:14 AM.
#2 KennyP ONLINE
  • 41,007 Thanks
  • 47,162 posts
Posted January 18, 2018 - 06:29 AM
Is the a starter/generator engine or does it have a starter and stator? I looked in the Operators manual and the wiring diagram there shows what looks like a 5 prong switch with the starter/stator. But the parts manual shows a 4 prong with starter/generator.
#3 ssmewing OFFLINE
ssmewing
  • 59 Thanks
  • 70 posts
Posted January 18, 2018 - 08:21 AM
I would say you missed that 2 wires go to one post. It is a 4 post ignition switch.
#4 boyscout862 ONLINE
  • 13,559 Thanks
  • 9,434 posts
Posted January 18, 2018 - 09:53 AM
Look closely at the switch blades. Each is labelled with a letter. Follow the wiring diagram and use a continuity tester to check everything before you connect the battery. I am going to have to rewire one of my Case 220s soon. Good Luck, Rick
