Any of our knowledgeable members have a JD M or MT ?
8 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,722 Thanks
  • 4,130 posts
Posted January 17, 2018 - 07:44 PM
Or maybe a JD 40. I have a question.
Noel
  • James Bosma said thank you
#2 James Bosma OFFLINE
James Bosma
  • 1,326 Thanks
  • 655 posts
Posted January 17, 2018 - 07:52 PM
Nope I am sorry I can't help
I only have WD 40
  • sharkman said thank you
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,327 Thanks
  • 4,953 posts
Posted January 17, 2018 - 08:08 PM
Lowell  [Grnspot110] has a 40
  • propane1 said thank you
#4 Cribs1450 OFFLINE
Cribs1450
  • 46 Thanks
  • 22 posts
Posted January 17, 2018 - 09:45 PM
I only have WD 40
I love it Haa!
#5 Leonard VanCamp ONLINE
Leonard VanCamp
  • 512 Thanks
  • 390 posts
Posted January 17, 2018 - 10:25 PM
Not sure if I can answer your question but ask away!
#6 propane1 ONLINE
propane1
  • 8,722 Thanks
  • 4,130 posts
Posted January 18, 2018 - 03:35 AM
Is it normal for one cylinder not to fire while idling. And as you put load on it it begins to fire. A JD A apparently works this way. A friend of mine has a JD MT and has number 2 cylinder not firing. Has spark, has 100 psi compression. Changed plug. Put gasoline in the cylinder put the plug back in. Still no fire.
Noel
  • Jazz and James Bosma have said thanks
#7 James Bosma OFFLINE
James Bosma
  • 1,326 Thanks
  • 655 posts
Posted January 18, 2018 - 03:10 PM
Have you tried swapping the spark plugs from onside to the other for curiosity
Does the JD M use the wasted spark system?, if so, you can switch plug wires and see if other cylinder is now dead
If not than one coil could be gone in the magneto, strong enough to spark without compression but not enough under compression
Picture of mag will help
My dad has rebuilt them before so with mag type and model I can ask him and reply with his suggestions
#8 jimmy G ONLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted January 18, 2018 - 07:34 PM
Try another plug wire frist, check for excessive shaft play in the distributor, if the intake valve sticks for just a millisecond the push rod will disconnect(you will still have compression),an intake leak will miss at idle and pick up under load, if one wire is longer than the other and the long one is missing could be a weak coil, if so switch wires and see if miss moves
  • propane1 and Leonard VanCamp have said thanks
#9 propane1 ONLINE
propane1
  • 8,722 Thanks
  • 4,130 posts
Posted January 18, 2018 - 08:21 PM
James Bosma. It is a points set up not a magneto. It sure is strange problem. Talked with a mechanic guy today who has an JD M. He really had no answers. An M and a MT have the same engine.
Noel
  • Leonard VanCamp and James Bosma have said thanks
