JD 140 Cigarette lighter information for you.
4 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,454 Thanks
  • 4,391 posts
Posted January 17, 2018 - 08:49 AM
If you have a JD 140 with the cigarette lighter, I found this out. I have knowen about this for awhile. I wanted to put a flashing light on the JD because of where I live. The people that drive up and down the road are mostly nuts. So I wanted to make myself and the tractor more visible while cleaning snow at the end of my driveway. I went to princess auto and bought a flashing light with the end that plugs into a power outlet. It was on sale too.
I knew the cigarette lighter didn't work on the tractor at this time , but I knew how to fix it. There is a manual resettable breaker built into the cigarette lighter. There is a all hole in the back of it that you push a small pin or wire in until you hear a click. This rests the lighter and you will have power there. I also cleaned up the connections in the lighter too while I was at it.
The way I found this out was, it was in the service book I have. It's nice to have the manuals. So, I hope this helps somebody out. May apply to other cigarette lighters also.
Noel
You have to take the battery out to reset the lighter, and I hung a wire in the tractor for this purpose.
  • Alc, jms180, EricFromPa and 11 others have said thanks
#2 jms180 ONLINE
jms180
  • 1,750 Thanks
  • 1,673 posts
Posted January 17, 2018 - 09:39 AM
it is very helpful to have a service manual thanks for the pictures
  • KennyP, Lmiller3358 and propane1 have said thanks
#3 KennyP ONLINE
  • 40,901 Thanks
  • 47,101 posts
Posted January 17, 2018 - 10:10 AM
I have a copy of the SM-2093 which is for the above 30001 units. Nice info to know!
  • Lmiller3358 and propane1 have said thanks
#4 Kster526 ONLINE
Kster526
  • 942 Thanks
  • 621 posts
Posted January 17, 2018 - 11:45 AM
Thanks for sharing, that’s one of those little things that someone will struggle
to figure out and you look like a genius if you can help.
  • propane1 said thank you
#5 hdg4400 ONLINE
hdg4400
  • 294 Thanks
  • 357 posts
Posted January 18, 2018 - 06:14 PM
propane1:
I also had a JD 140 with a cigarette lighter, and using the manual found out how to reset it. I had a cab for the 140, and used a small fan that plugged into that socket to try to keep the cab windshield clear in the winter. I also tried to power an old car radio and speaker that I mounted on the tractor. The lighter socket powered them fine, but neither really did what I wanted. Not enough air movement by the fan, and too noisy a tractor for the radio.
Harlan
