toro pusher
7 replies to this topic
#1 old coot ONLINE
old coot
  • 135 Thanks
  • 95 posts
Posted January 16, 2018 - 05:28 AM
been dealing with this problem for 2 years now....I have a 6.5 Tecumseh on a toro GTS  self propelled...it's a bear to start unless I shoot a little starting fluid around air cleaner then it will start right up first pull, after I run it and it gets warm it will start first pull every time when at operating temperature, carb has been cleaned a few times, primer bulb replaced , getting gas to carb, what's next ?  just don't understand why it wont start easy after sitting a few days or so
  • chieffan said thank you
#2 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,298 Thanks
  • 10,283 posts
Posted January 16, 2018 - 07:52 AM
How's the compression?
#3 old coot ONLINE
old coot
  • 135 Thanks
  • 95 posts
Posted January 16, 2018 - 08:19 AM
not sure about compression, I have no way to check it,,,i have to say it does run strong once I get it started, doesn't bog down even in tall wet grass
#4 Bolens 1000 OFFLINE
  • 15,540 Thanks
  • 18,316 posts
Posted January 16, 2018 - 09:12 AM
If compression is satisfactory and you are sure you have no air leaks at any of the manifold brackets/gaskets the issue still lies in the carb could be a simple spec of dirt somewhere, these do have a non serviceable atmospheric vent that can become clogged , a new carb will be the solution to that issue.
What model Tecumseh ?
I would likely have the carb instock new
  • KennyP, LilysDad, old coot and 1 other said thanks
#5 old coot ONLINE
old coot
  • 135 Thanks
  • 95 posts
Posted January 16, 2018 - 11:18 AM
model 20017   serial 240016760
#6 Bolens 1000 OFFLINE
  • 15,540 Thanks
  • 18,316 posts
Posted January 16, 2018 - 11:23 AM
I stock the carb they are $66.00 FREE SHIPPING
They are Genuine USA made Tecumseh carbs
I have air cleaners and any other parts you may need, if interested send me a PM
#7 Bolens 1000 OFFLINE
  • 15,540 Thanks
  • 18,316 posts
Posted January 18, 2018 - 03:38 PM
Did you solve your problem?
#8 old coot ONLINE
old coot
  • 135 Thanks
  • 95 posts
Posted January 19, 2018 - 05:27 AM
haven't got around to it yet ...been way to cold to work on anything in a unheated garage
