Search for Sears 2464R mower blades
sears 2464 oregon 95-013 st-10 tractor
9 replies to this topic
#1 bolton88 OFFLINE
bolton88
  • 3 posts
Posted January 15, 2018 - 02:50 PM
Searching for preferably new mower blades for 38" deck on Sears ST-10 tractor mower.  Blade part number is 2464R which seems to be same as Oregon 95-013, both not in stock.   Blade is 19.5" on the diagonal and the hole is a double D shape with dimensions of 1.25" long by 7/8ths inch wide.  Any help appreciated.
#2 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted January 15, 2018 - 03:35 PM
:wave:  Welcome to the forum! Think I have found you some! I did some searching for the Oregon part # and found this:
https://screenshots....wnmowerpros.com
I scrolled down and found this:
Here's the site:
https://www.lawnmowe...ower-blades.asp
EDIT: Then again, I might be wrong as it doesn't say the center hole is oblong! Maybe you can contact them and see what they say!
Edited by KennyP, January 15, 2018 - 04:12 PM.
  • bolton88 said thank you
#3 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted January 15, 2018 - 03:50 PM
Heres the specs for the blades Kenny referenced above they are $10.00 ea from me
C. H. DIA:  5/8"
CENTER TO CENTER (OUTSIDE HOLES):  1-7/8"
CUT DIRECTION:  RIGHT
DIAMETER OF OUTSIDE HOLES:  3/8"
LENGTH:  20"
THICKNESS:  0.1340"
WIDTH:  2-1/2"
The 1044R blade adapters I stock and they run $5.10 EA
Let me know if you need any other info I'll gladly post it
#4 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted January 15, 2018 - 04:17 PM
I hope the blade adapters will fit his spindles!
#5 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted January 15, 2018 - 04:21 PM
The blade adapters are original sears specs so that should not be an issue as much as the blades if they will fit
#6 4getgto OFFLINE
4getgto
  • 28 Thanks
  • 30 posts
Posted January 16, 2018 - 07:03 PM
Are these the blade adapters that shear when you hit something?
#7 bolton88 OFFLINE
bolton88
  • 3 posts
Posted January 18, 2018 - 01:13 PM
Yes, Oregon 95-013 blade is exact replacement for Sears 2464R blade, BUT Oregon's statement that their 95-024 blade is now the substitute for the 95-013 is a problem   The 2464R and the 95-013 have a double D shaped hole (a rectangle with rounded ends) whereas the 95-024 is a star shaped hole.   Perhaps one could change the star to a double D, but would be difficult and possibly not safe.  Unless Oregon attached the wrong image to their 95-024 blade info.??
#8 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted January 18, 2018 - 01:15 PM
https://bolenspartsa...y-washer-1044r/
  • 4getgto said thank you
#9 4getgto OFFLINE
4getgto
  • 28 Thanks
  • 30 posts
Posted January 18, 2018 - 01:32 PM
Surprised these are still available.
#10 bolton88 OFFLINE
bolton88
  • 3 posts
Posted January 19, 2018 - 02:10 PM
The 1044r  shear washers are designed to break if you hit something, or if the "C" ring on the splined shaft into the gear box breaks and the shaft comes out of the gear box, and allows the blades to  be other than 90 degrees apart, thus hit each other.  They are rare, but available.   Even more rare and apparently NOT available is the cutting blade, 2464R that fits with these washers.
Also tagged with one or more of these keywords: sears, 2464, oregon 95-013, st-10 tractor
