Question for the tractor builders
17 replies to this topic
#1 KennyP ONLINE
  • 41,500 Thanks
  • 47,416 posts
Posted January 14, 2018 - 05:03 PM
Has anyone ever thought of making a tandem rear drive using 2 Sundstrand hydros? Could it be done? Thinking a walking beam type axle, u-joint driveline to it. Just looking for feedback.
  • boyscout862, Leonard VanCamp, chieffan and 1 other said thanks
#2 chieffan ONLINE
  • 11,784 Thanks
  • 7,287 posts
Posted January 14, 2018 - 05:24 PM
Are you thinking one behind the other?  Would be an interesting project for sure.
  • KennyP and Mark 149 J. have said thanks
#3 KennyP ONLINE
  • 41,500 Thanks
  • 47,416 posts
Posted January 14, 2018 - 05:45 PM
Yes. Nothing set in stone, just a concept to think about!
  • boyscout862, chieffan and Mark 149 J. have said thanks
#4 Trav1s ONLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted January 14, 2018 - 05:52 PM
Why two separate pumps?  I can see the benefit from a fabrication point but the rest leaves me  :watch_over_fence:
  • Leonard VanCamp, chieffan and Mark 149 J. have said thanks
#5 KennyP ONLINE
  • 41,500 Thanks
  • 47,416 posts
Posted January 14, 2018 - 05:58 PM
How else would you get both driving?
  • propane1, Leonard VanCamp, chieffan and 1 other said thanks
#6 chieffan ONLINE
  • 11,784 Thanks
  • 7,287 posts
Posted January 14, 2018 - 06:07 PM
Would have to have two pumps or the back one would just be a tag axle and no benefit.  Unless one could use a track between the front and rear wheels on each side ? ?
Edited by chieffan, January 14, 2018 - 06:08 PM.
  • KennyP, Leonard VanCamp and Mark 149 J. have said thanks
#7 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted January 14, 2018 - 06:14 PM
Sprockets on the inside of the hub and chain driven?
  • KennyP and Leonard VanCamp have said thanks
#8 olcowhand ONLINE
  • 43,177 Thanks
  • 32,012 posts
Posted January 14, 2018 - 06:17 PM
Easiest way would be using Case rear ends.  One pump to feed both rear motors in series.  I know you asked about Sundstrand, but they would complicate things.
  • KennyP, Trav1s, propane1 and 1 other said thanks
#9 KennyP ONLINE
  • 41,500 Thanks
  • 47,416 posts
That's more work than a shaft connecting the two.
  • Mark 149 J. said thank you
#10 KennyP ONLINE
  • 41,500 Thanks
  • 47,416 posts
Posted January 14, 2018 - 06:18 PM
Don't have Case goodies, but I have 2 Sundstrands!
#11 dropped82 ONLINE
dropped82
    Nut Case
  • 2,771 Thanks
  • 1,916 posts
Posted January 14, 2018 - 06:55 PM
I have a few extra Case rears with drive motors. They are not permanent in my shop.
Sent from my iPad using Tapatalk
#12 James Bosma ONLINE
James Bosma
  • 1,589 Thanks
  • 755 posts
Posted January 14, 2018 - 09:27 PM
Hmmm think I know where your going and think maybe possible
if the walking beam pivots at the front of setup, would make driveshaft easier, more compact
The U-joint needs to be inline with the pivot, if not the length of drive shaft changes and then other problems can occur
Jack shaft  will have to run above / beside the rear ends
either gear cluster of 3 or belt drive from jack shaft to hydro pumps
Edited by James Bosma, January 14, 2018 - 09:38 PM.
#13 1oldbuzz OFFLINE
1oldbuzz
  • 619 Thanks
  • 490 posts
Posted January 15, 2018 - 02:03 AM
I may be out in left field
but I think connecting the 2 pumps is the easy part
I would be concerned with synchronizing the control
of the pumps forward/reverse
If not in sync its like a 4x4 with different
gears front and rear
one will work against the other
  • KennyP, CRFarnsworth and Leonard VanCamp have said thanks
#14 KennyP ONLINE
  • 41,500 Thanks
  • 47,416 posts
Posted January 15, 2018 - 05:36 AM
Thanks everyone. This is just a thought right now.
I got to thinking about that pivot last night and have to agree with this. It would take some thought process to make it work. Maybe limit the travel to help with this.
I was also wondering about the control (fwd/rev), but an adjustable rod between the units would help getting that right. Then you have to think about the brakes that are outboard by the wheels.
  • CRFarnsworth, Leonard VanCamp, James Bosma and 1 other said thanks
#15 KennyP ONLINE
  • 41,500 Thanks
  • 47,416 posts
Posted January 17, 2018 - 03:10 PM
Been thinking about this and I don't know if these two are the same series yet. If not, my idea may not work! I know one is a series 15, not sure about the other.
