Ariens GT14 regulator/rectifier
5 replies to this topic
#1 v8george OFFLINE
v8george
  • 6 posts
Posted January 11, 2018 - 12:01 AM
Hi, looking for a regulator/rectifier for a GT14 Gear with the Kohler engine. Model 931021 serial number 000384.
The part I am coming up with is Ariens 03110900. Is that the only part available or does it cross reference with another manufacturer?
pic of burned up part
https://photos.app.g...S1SNDyYSaGCRfh1
#2 KennyP ONLINE
  • 40,942 Thanks
  • 47,128 posts
Posted January 11, 2018 - 05:43 AM
I googled it and they are right proud of that thing. I am pretty sure that regulator was used on other brands, just not sure where. Hopefully Bob can cross it for you.
#3 James Bosma OFFLINE
James Bosma
  • 1,478 Thanks
  • 729 posts
Posted January 11, 2018 - 07:24 AM
Looks a lot like the one on my Massey MF 14
#4 TAHOE ONLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted January 11, 2018 - 08:25 AM
As long as your system has two AC+ terminals and then the other going to battery or ammeter, then you can use a generic one. Charging system doesn't care what it looks like, just as long as it has the 2-AC and B+ terminals.
I had one similar to yours on my Sears with a Tecumseh, I switched over to these generic ones and it's fine. I did run a  separate little ground wire form the mounted bolt just to make sure I had good ground and I had to cut off my factory terminals and crimp on spade connectors.
I do a search on ebay for an Onan voltage regulator, just make sure I get one rated for 20amps.
  • v8george said thank you
#5 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted January 11, 2018 - 08:44 AM
New OEM one will be $140.36 I can also get you a aftermarket one for $89.50. Both the OEM and aftermarket one will look different but bolts up and plugs in the same. I will pm you our number if you want to call.
#6 dodge trucker ONLINE
dodge trucker
  • 2,820 Thanks
  • 3,457 posts
Posted January 11, 2018 - 01:30 PM
Most electrical parts like that, Ariens Deere, wheel horse etc don't make themselves anyhow, they get them from a supplier,rebox them and Jack the price for the privilege....
  • jms180 said thank you
