other k361 advice.....on power king 2418
18 replies to this topic
#1 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 10, 2018 - 08:11 PM
I put most of the 2418 back together and tried to  start it up and noticed gas misting out of the carb.  On the way home i remembered that i had a new intake seat put in head.  I totally forgot about the valve work....I'm guessing that the intake is not closing all the way and needs proper play on the top gaped to specs in the manual.  The rocker is probably to tight and not seating the intake properly and i'm seeing blow back through the carb.   Any opinions would be appreciated.
jim
  • chieffan said thank you
#2 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,112 Thanks
  • 10,183 posts
Posted January 10, 2018 - 09:47 PM
Of course, after a rebuild, all necessary adjustments must be done.
  • chieffan and bazil.w.duke have said thanks
#3 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,796 Thanks
  • 5,094 posts
Posted January 10, 2018 - 10:08 PM
The compression release will hold the intake slightly open until the engine starts.
#4 dodge trucker ONLINE
dodge trucker
  • 2,814 Thanks
  • 3,451 posts
Posted January 10, 2018 - 10:09 PM
No, that's the exhaust/
  • Gtractor, chieffan and bazil.w.duke have said thanks
#5 Gtractor OFFLINE
Gtractor
  • 9,796 Thanks
  • 5,094 posts
Posted January 10, 2018 - 10:12 PM
Don't argue with me when I've just put in a 15 hour day.  :poke:   :wave:
#6 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 10, 2018 - 10:25 PM
And let me tell you how much fun it is getting those push rod tubes in the block and head......I might have alarmed the passer byers in front of our wharhouse
#7 chieffan OFFLINE
  • 11,346 Thanks
  • 7,106 posts
Posted January 10, 2018 - 10:26 PM
Poor boy, have to work this winter.  :shoot2:  :rocker2:     :thumbs:
  • Gtractor and bazil.w.duke have said thanks
#8 EricFromPa ONLINE
EricFromPa
  • 4,178 Thanks
  • 3,352 posts
Posted January 10, 2018 - 10:34 PM
Did the machine shop Lap the valves in?  Set valve lash at TDC on the Compression stroke. There is a bit of valve overlap where both valves will be open slightly on TDC of the exhaust stroke. You can find TDC by a | or T mark on the flywheel visible through a hole in the side of the blower housing on the Carburetor side.
Video explaining all 4 strokes.
Please tell me you removed those Balance gears. Those puppies were Shot. Seriously it's not a matter of IF they will let go it's WHEN will they let go.
  • bazil.w.duke said thank you
#9 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 10, 2018 - 10:49 PM
that is a great video
#10 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 11, 2018 - 05:45 PM
here it is running again
  • DH1 and Dayton_King have said thanks
#11 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 11, 2018 - 06:20 PM
i want to thank all of you for your help!!!!!!!
  • Dayton_King said thank you
#12 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 11, 2018 - 08:26 PM
I did notice something that has me thinking when the engines running on the k361 and I pull out the dipstick there are pressure and vacuum surges that you can definitely see and feel and hear what does that indicate?
#13 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 11, 2018 - 10:14 PM
going to do the clear tube water test tomorrow
#14 MNGB OFFLINE
MNGB
  • 2,621 Thanks
  • 1,569 posts
Posted January 11, 2018 - 10:15 PM
It indicates the piston is going up & down the engine is running your getting oil to the overhead to lube the valves that a pulse fuel will work and that all is normal.
It sounds good.
Edited by MNGB, January 11, 2018 - 10:17 PM.
#15 bazil.w.duke OFFLINE
bazil.w.duke
  • 115 Thanks
  • 108 posts
Posted January 11, 2018 - 10:26 PM
sweet.....
