GT5000 Kohler engine acting weird
21 replies to this topic
#1 rover OFFLINE
rover
  • 8 Thanks
  • 11 posts
Posted January 09, 2018 - 02:43 PM
New guy,
I upgraded my computer and have hi-speed internet, these repair forums are great. I couldn't download information before on a 97 laptop and dial-up. I also appreciate these forums, lots of good information.
I searched thru the posts, but didn't find my problem.
I have a 2006 GT-5000 with a Kohler engine  CV730-0044
When starting the engine, throttle is midway, 1/2 choke is applied and engine pops right off.  If the choke is pushed back to open, the engine dies.  If I keep the choke between 1/2 and 3/4, the engine will stay running. (very variable)
Sounds like it needs more gas, right.
Checked fuel line-ok
Checked impulse pump-ok
Cleaned carb, cleared jets, new float and needle (actually carb was very clean)
Fuel Shut-off solenoid worked
new carb intake gaskets-torqued to 10 ft lbs
Checked cylinders for blown head gasket-160psi
Possible cause would be carb pump, but everything look good when disassembled
Governor wasn't messed with
Any suggestions?
Thanks
#2 KennyP ONLINE
  • 38,441 Thanks
  • 45,958 posts
Posted January 09, 2018 - 06:22 PM
:wave:  Welcome to the forum!
Possibly a partially blocked fuel line? Something in the tank? How about the fuel pump sucking fuel into the crankcase? Try smelling the dipstick for gas.
#3 rover OFFLINE
rover
  • 8 Thanks
  • 11 posts
Posted January 09, 2018 - 07:22 PM
Kenny, thanks for the comments,
fuel line clear. pulse pump works fine
no fuel smell in oil
As I think about this, maybe I need to look at the slow air bleed jets, maybe I missed something.
Thanks
#4 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted January 10, 2018 - 02:55 AM
2006
I assume it has an integrated choke/throttle
theres the problem
position will change with the weather
I never cared for that system
no engine should fire at full throttle
#5 KennyP ONLINE
  • 38,441 Thanks
  • 45,958 posts
Posted January 10, 2018 - 05:20 AM
2006
theres the problem
On the 2 CV730's I have the choke is separate from the throttle.
I haven't had this type issue with mine, so not sure what could be the problem. It's gotta be in the carb.
#6 rover OFFLINE
rover
  • 8 Thanks
  • 11 posts
Posted January 10, 2018 - 09:11 AM
1oldbuzz, no choke and throttle are separate.
Kenny, the problem has to be the carb.  It was running great before hand.  Something came into the carb, either thru the air cleaner or the gas line.  Will have to check these passage ways very carefully.  The pump on the side of carb looks fine, rubber pliable.
I hope I can find the problem as a new carb is $360.00!
Will post my progress as I go.
#7 KennyP ONLINE
  • 38,441 Thanks
  • 45,958 posts
Posted January 10, 2018 - 09:17 AM
Yours has the fuel pump on the carb? Both of mine have the pump mounted to the side of the engine. Like this:
https://screenshots....w.partstree.com
#8 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,473 Thanks
  • 5,772 posts
Posted January 10, 2018 - 09:34 AM
Is the float level set right?  If the fuel level in the bowl is too high that would explain your trouble..
#9 rover OFFLINE
rover
  • 8 Thanks
  • 11 posts
Posted January 10, 2018 - 09:39 AM
KennyP,
Pulse pump mounted on engine.
There is a round mount on opposite side of gas supply hose of carb. It is attached to the bowl. The bowl bleeds into this "pump"thru a rubber pad that must open due to vacuum.  One line travels to just below choke and other line to air bleeders on top of carb.  Both lines appear to be open, but I'm re-checking the again.
#10 rover OFFLINE
rover
  • 8 Thanks
  • 11 posts
Posted January 10, 2018 - 09:42 AM
WNY
The float is not adjustable.
New float, oem part, one piece plastic float and stop tang
#11 KennyP ONLINE
  • 38,441 Thanks
  • 45,958 posts
Posted January 10, 2018 - 09:51 AM
KennyP,
I'd have to go out and look at mine to see what you are talking about. Anyway to post some pics?
#12 crittersf1 ONLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted January 10, 2018 - 10:12 AM
Vacuum leak?
#13 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,473 Thanks
  • 5,772 posts
Posted January 10, 2018 - 10:44 AM
https://www.google.c...I9gN-DTHNJt0JI2
#14 rover OFFLINE
rover
  • 8 Thanks
  • 11 posts
Posted January 10, 2018 - 01:08 PM
This is a picture of the carb  24-053-102  from e-bay
Critter
vacuum leak possible, but from where?   Gaskets are new on both ends of carb.  I torque them to 10 ft lbs.
WNY
I have been studying the fuel system part of that manual for a couple days.  The carb diagrams do not show my carb.
There are no adjustments on this carb if you exclude the idle set screw.  That has not been changed.
Dis-assembled carb, took extra care in cleaning all port holes, removed 2 jets, look good, dis-assembled  that "pump"
on the side-looks good.  Every hole in the carb allows air movement.  Will put it back on engine today.  Will post either way.
  • KennyP and WNYTractorTinkerer have said thanks
#15 rover OFFLINE
rover
  • 8 Thanks
  • 11 posts
Posted January 11, 2018 - 12:32 PM
Well, cleaned carb  again especially checking the low speed circuit route.  Pulled main jet and bleeder air jet, everything clear.
Re-checked solenoid, moves up and down multiple times.  Checked intake manifold-no cracks-gaskets good,  pulse pump pumps lots of gas.
So starting tractor cold with throttle 1/2 open and choke 1/2 closed, engine starts after third cycle.  Full throttle and almost full choke,
engine runs like it should.  Push choke in and engine stalls.  1/2 throttle with 1/2 choke, engine runs fine.  Push coke in and engine stalls.  No backfires, just dies.  Pulled spark plugs and plug ends are not black.
Thanks everyone for your suggestions.
