s-16h rear end question
7 replies to this topic
#1 kcbm1970 OFFLINE
kcbm1970
  • 1 Thanks
  • 3 posts
Posted January 08, 2018 - 07:03 PM
Hello, new to the forum, just had a question.  My rear end in my s-16h tractor is leaking oil really bad after getting the tractor stuck, none of the fitting seem to be leaking.  Does anyone know if a rear end (trans and hydro) from a gt20 would work in my tractor?
Thanks,
Carl
#2 boyscout862 OFFLINE
  • 12,831 Thanks
  • 9,158 posts
Posted January 08, 2018 - 11:51 PM
Welcome to GTT. You can go to the Manuals Section(3 free downloads per day) and check the manuals for the two tractors. You could also post pics of each. Good Luck, Rick
  • kcbm1970 said thank you
#3 shorty OFFLINE
shorty
  • 5,468 Thanks
  • 5,257 posts
Posted January 09, 2018 - 05:12 AM
Welcome to the forums!
There are small differences between the two. Good chance a few mounting points won't line up. But overall it should fit in.
#4 dodge trucker OFFLINE
dodge trucker
  • 2,423 Thanks
  • 3,116 posts
Posted January 09, 2018 - 06:58 AM
might be easier to find and fix the leak. I had to replace all the hoses on my GT19 as I bought it with one blown and shortly after getting it running for the 1st time another popped a pinhole. Its unbelieveable how much fluid will blow out from just a pinhole.....  could be just an axle seal.... might be easier to fix what you have,  chances are you might swap axles and still have a leak.....
#5 kcbm1970 OFFLINE
kcbm1970
  • 1 Thanks
  • 3 posts
Posted January 09, 2018 - 10:02 AM
Thank everyone for your advice, I will try to get a good look at it tomorrow, it'll be a little warmer and I'm hunting today (last day of muzzle loader season).  The tractor has been my go-to since I bought it 9 years ago...for $900 with a cab, blower, weight box, and deck.  I will get it fixed, nothing they make today can touch it.  If anyone has more suggestions, please let me know.
Carl
Edited by kcbm1970, January 09, 2018 - 10:17 AM.
#6 shorty OFFLINE
shorty
  • 5,468 Thanks
  • 5,257 posts
Posted January 09, 2018 - 01:16 PM
Check the hoses running to the hydraulic valve. They can leak onto the rear making it look like the rear is leaking. Been there already.
#7 kcbm1970 OFFLINE
kcbm1970
  • 1 Thanks
  • 3 posts
Posted January 10, 2018 - 11:23 AM
Checked the hoses, appears to be leaking between the hydro and rear end....pretty dirty in there, I'm going to have to give it a good cleaning before I can pinpoint the leak.  Not the time of year I wanted to be doing this. :wallbanging:
#8 dodge trucker OFFLINE
dodge trucker
  • 2,423 Thanks
  • 3,116 posts
Posted January 10, 2018 - 01:20 PM
There's a gasket in between there.
  • KennyP and kcbm1970 have said thanks
