Ford/Gilson LGT18H wiring help
2 replies to this topic
#1 Firemang OFFLINE
Firemang
  • 187 Thanks
  • 197 posts
Posted January 07, 2018 - 04:09 PM
The Ford/Gilson made lgt18h I’m restoring is giving me a ton of grief with the wiring. I have the schematic from the manual and have been tracing wires the last two weeks and am confused as when I started. The previous owner didn’t know what he was doing and tried to get it running by cutting into the harness in numerous places and I can’t make heads or tails of anything at this point and I’m thinking about just tearing everything out, getting a new solenoid, switches and key switch and completely running all new wires. I was wondering if anyone has a basic schematic for this tractor (a lot going on with the factory wiring with safety switches, oil pressure sensors, etc. would rather just bypass all of it) that will get the engine to crank and fire, the pto to work, the headlights, anmeter, and hour meter to work and that’s it. This machine has the Kohler Magnum 18 opposed twin engine if that helps. Thanks
#2 KennyP ONLINE
  • 40,927 Thanks
  • 47,123 posts
Posted January 07, 2018 - 04:35 PM
I don't have anything that would help!
  • boyscout862 and Firemang have said thanks
#3 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 487 posts
Posted January 08, 2018 - 01:20 AM
If you have the schematic
I would tear out and start over
test all of the current switches
replace only those that are bad
most of the safety switches just
complete the ground they are
easy to bypass
  • Firemang said thank you
