JD322
19 replies to this topic
#16 propane1 ONLINE
propane1
  • 9,443 Thanks
  • 4,384 posts
Posted January 09, 2018 - 05:06 PM
Yes I know those deals. Want more than need. Nice to think about thou and like you say, made good conversation.
Noel
#17 GardnMastr OFFLINE
GardnMastr
  • 399 Thanks
  • 203 posts
Posted January 09, 2018 - 07:33 PM
Here in Indiana, with heavy grass, the 50" doesn't work. The 46", although not as tall or deep, has a much wider discharge area. It will really sling the grass out. The 50"s discarge is choked down terribly, it clogs and clumps. If you every had both decks upside down side by side the difference is striking. I have a 332 and I was thrilled it came with the 46 instead of the 50. I realize it's an opinion but truly the 46 performs.
  • propane1 said thank you
#18 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 658 Thanks
  • 473 posts
Posted January 09, 2018 - 07:38 PM
The 50" is better setup for a bagger or trac vac.
#19 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted January 09, 2018 - 08:19 PM
If you ever want to burn a ridiculous amount of fuel, put the speed up pulley on the 50 deck, then attach a powerflo with the mc cart, and go mow really lush grass. The last time that happened, Exxon stock went up 8%.
  • dropped82 said thank you
#20 pryan05 OFFLINE
pryan05
    LGT
  • 673 Thanks
  • 369 posts
Posted January 12, 2018 - 04:27 PM
No........Decided to stick with what I have for now......One of those deals more of want than need......Made for interesting conversation though.
Check this one out Poncho!  Rolling coal is a thrill!
https://www.kijiji.c...gationFlag=true
  • KennyP and propane1 have said thanks
