Ford LGT single stage snow blower
7 replies to this topic
#1 JAM OFFLINE
JAM
  • 9 Thanks
  • 6 posts
Posted January 05, 2018 - 03:14 PM
The bronze bushing for the input sprocket shaft has worn away on my single stage snow blower. I could not find a Ford parts manual, however, I did find a parts manual by Oliver for a 1972 42" single stage snow blower that looks to be the same. The part # for the bushing is JX352374. I have had no luck finding somewhere to purchase the part. Has anyone else had to replace this before? I understand it is a part that needs replacing frequently.
Thanks
#2 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 10,265 Thanks
  • 3,329 posts
Posted January 05, 2018 - 04:06 PM
Thanks
Do you have a model number of your snow blower?  A lot of the Ford Lawn and Garden tractors parts break down can be found on the Ford / New Holland website - sent you a pm with the link and a picture of one snow thrower parts break down I found - not sure if it is the correct one??
  • boyscout862 and JAM have said thanks
#3 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted January 05, 2018 - 04:22 PM
Alot of the bearings and bushings used on our equipment are generic. If you take the old one or the measurements to a bearing dealer, He can probably match what you need. Good Luck, Rick
  • JAM and John Arsenault have said thanks
#4 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,459 Thanks
  • 4,577 posts
Posted January 05, 2018 - 05:49 PM
Check ACE Hardware, or Tractor Supply, I get a lot of my bushings from there. Much cheaper than Dealer parts.
#5 propane1 OFFLINE
propane1
  • 9,451 Thanks
  • 4,389 posts
Posted January 05, 2018 - 06:46 PM
I took the two out of mine and put in self centering bearings. Easy to get at any tractor supply place.
Noel
#6 TomLGT195 OFFLINE
TomLGT195
  • 4,051 Thanks
  • 2,900 posts
Posted January 06, 2018 - 08:02 AM
:welcometogttalk: &  :wewantpics: please.
#7 pryan05 OFFLINE
pryan05
    LGT
  • 673 Thanks
  • 369 posts
Posted January 06, 2018 - 08:55 AM
Mine were replaced with flanged roller bearings. Greasable, they should last a long time. I beleive it is a 3/4" shaft.
#8 JAM OFFLINE
JAM
  • 9 Thanks
  • 6 posts
Posted January 08, 2018 - 11:47 AM
Thanks everyone for responding. I found some brass bushing at TSC Store that will hold me over until the snow stops falling and I can find time to retrofit with bearings.
  • boyscout862, TomLGT195 and propane1 have said thanks
