1968 Super 12 axel seals
#1
OFFLINE
Posted January 05, 2018 - 07:23 AM
I need some advice on where to buy replacement axel seals for my 68 Super 12. My
manual shows it as item #20 with a part number 4910H with the verbiage of oil seal. I
would like to a low cost alternative if I can find one. Thanks in advance.
- 6mikey7 said thank you
#2
OFFLINE
Posted January 05, 2018 - 07:30 AM
SKF Oil seal part #9838
- KennyP and 6mikey7 have said thanks
#3
ONLINE
Posted January 05, 2018 - 08:28 AM
Those seals would work on a bunch of the early Sears tractors I think?
- 6mikey7 and det12187 have said thanks
#4
OFFLINE
Posted January 05, 2018 - 08:45 AM
I am not sure, I put new axle seals in my 68 manual and those are what I used. I believe they are the same for many other suburbans but I would not put a guarantee on it with out looking into it first.
9410H is SFK #9838 that I know because I been down that road.
- KennyP, 6mikey7 and det12187 have said thanks
#5
OFFLINE
Posted January 05, 2018 - 01:40 PM
cheap enough. I have another question what is the correct oil to use
in this rear end? My manual says 30 weight is that correct? Thanks in
advance.
#6
OFFLINE
Posted January 05, 2018 - 02:32 PM
Yep.
- det12187 said thank you
