sunstrand charge pump check
26 replies to this topic
#1 BOLENSBOY60 OFFLINE
BOLENSBOY60
  • 40 Thanks
  • 47 posts
Posted January 04, 2018 - 10:01 AM
got the proper gauge and re-rested pressure- good  pressure at 120 psi- but when I dead head the aux. hydraulics- the pressure jumps up a little bit- then drops back down- I already replaced the implement relief valve-spring ect. tough one to diagnose
  • boyscout862, Sawdust and Mark 149 J. have said thanks
#2 boyscout862 ONLINE
  • 12,570 Thanks
  • 9,050 posts
Posted January 04, 2018 - 10:50 AM
Did you run all of the tests in the series?
#3 BOLENSBOY60 OFFLINE
BOLENSBOY60
  • 40 Thanks
  • 47 posts
Posted January 04, 2018 - 12:07 PM
did you mean the hi pressure- which I think is for the acceleration valves? did not do that one- but I tested the drive to the whels- by bumping the bucket against the foundation- dug it right down seems to have good drive power- thank you for your input really want to eliminate everything I can before removing the hydro -
#4 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted January 04, 2018 - 01:19 PM
I have no idea about this machine, but does the lift valve have a relief adjustment? It may have backed out and won't let it build pressure! Or maybe the lift valve needs rebuilt!
#5 BOLENSBOY60 OFFLINE
BOLENSBOY60
  • 40 Thanks
  • 47 posts
Posted January 04, 2018 - 02:07 PM
thank you for your thoughts- my machine- an Bolens HT-20 - does not have adjustable control valve. it has a charge relief and implement relief valve internal to the hydro. although I did remove it and replaced the o rings- just to eliminate that possibility
#6 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted January 04, 2018 - 02:15 PM
I know nothing about Bolens, but it was a thought!
#7 HowardsMF155 OFFLINE
  • 2,841 Thanks
  • 2,979 posts
Posted January 04, 2018 - 04:32 PM
Are you running the machine at WoT or whatever throttle position is recommended?
#8 BOLENSBOY60 OFFLINE
BOLENSBOY60
  • 40 Thanks
  • 47 posts
Posted January 04, 2018 - 07:19 PM
hi Howard- yes- wot I get the 120 to 125 psi reading- when at about 1/4 throttle I get around 75 psi - I just cannot figure out why if I have the specified pressure coming from the charge pump -why the power steering will not have much power- when I take the bracker off the frame and operate the steering wheel the cylinder movers in and out- and my lift cylinder looks like it is slow also- and when I dead head the cylinder it should jump to around 550 to 800 psi according to the manual-- i.e. implement relief pressure- but mine jumps up about 10 psi then drops back - it should have been as simple as replacing the implement relief valve-
  • Mark 149 J. said thank you
#9 chieffan ONLINE
  • 9,623 Thanks
  • 6,434 posts
Posted January 04, 2018 - 08:40 PM
I still think it is the cylinder seals.  If they are bad it would not build pressure due to the by passing of fluid in the cylinder.
#10 BOLENSBOY60 OFFLINE
BOLENSBOY60
  • 40 Thanks
  • 47 posts
Posted January 05, 2018 - 06:36 AM
wow chieffan -you have quite a herd their! I was hoping that was it too- but after I replaced the o rings in the control valve- and I have the spools centered- still cannot get the relief pressure to build- my tractor has dual hydraulic aux. ports also- and  I use that to dead head the system still will not build implement relief pressure- maybe today I will take the hoses off the lift cylinder and connect together and just to see thanks for you input
#11 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted January 05, 2018 - 06:49 AM
This is just a long shot but since this tractor has an unknown past could the relief valves be switched ?  I might not even be possible I'm just throwing it out there
#12 BOLENSBOY60 OFFLINE
BOLENSBOY60
  • 40 Thanks
  • 47 posts
Posted January 05, 2018 - 07:20 AM
I did replace the implement relief with all new parts- however I did not replace the charge relief- I do see the spring in the charge relief is a heck of lot weaker or softer than the implement relief- I wonder if I have the correct spring? thanks for the heads up alc!
  • KennyP and Mark 149 J. have said thanks
#13 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted January 05, 2018 - 08:16 AM
That might just be the issue!
#14 BOLENSBOY60 OFFLINE
BOLENSBOY60
  • 40 Thanks
  • 47 posts
Posted January 05, 2018 - 08:59 AM
first thing I will do is replace that charge relief spring- also want to do the aux leak test
#15 BOLENSBOY60 OFFLINE
BOLENSBOY60
  • 40 Thanks
  • 47 posts
Posted January 05, 2018 - 02:17 PM
I swapped the charge relief spring- no luck -I drained the fluid- this looked a lot darker and thicker than type F after new filter and fluid- I have zero charge pressure- nothing- I filld the pick up line- filled the new filter andremoved the plugs and rotated the engine like the book says- nothing- maybe someone put thick fluid in their to compensate for wear?
