16 foot Trailer
44 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,660 Thanks
  • 3,190 posts
Posted January 02, 2018 - 07:10 PM
Me and my uncle is talking about selling off the 4x7 trailer and the 4x12 trailer and buying one of these 16 footers. Right now if we wanted to take all the tractors to show we have to make multiple trips.
https://killeen.crai...6424055589.html
  • hamman, KennyP, EricR and 1 other said thanks
#2 cootertom OFFLINE
cootertom
  • 1,614 Thanks
  • 835 posts
Posted January 02, 2018 - 07:41 PM
What I've found in the past is if they paint the wood it's probably isn't pressure treated. They will tell you it is BUT!!!!
  • KennyP, bbuckler and Reed Breneman have said thanks
#3 bbuckler OFFLINE
bbuckler
  • 3,660 Thanks
  • 3,190 posts
Posted January 02, 2018 - 07:47 PM
Still cheaper than what I found them used for
  • Reed Breneman said thank you
#4 JBRamsey OFFLINE
JBRamsey
  • 1,541 Thanks
  • 869 posts
Posted January 02, 2018 - 07:56 PM
That is cheap. If the axles have a decent rating on them, that's a good deal. Even if you have to redeck it five years down the road.
  • bbuckler and Reed Breneman have said thanks
#5 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted January 02, 2018 - 08:53 PM
Do your homework....
I bought a 18 footer that was supposed to be D.O.T. compliant, but it wasn't!
I completely rewired it, added a "break-away" switch & battery, all new LED lights, and added the extra lights for the D.O.T compliance.
It also only had 1 "brake" axle, and the underneath side of the trailer wasn't painted. Had to repaint after 1 year, and replace some boards after 2 years.
  • bbuckler, MGP59DB and Reed Breneman have said thanks
#6 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,482 Thanks
  • 6,175 posts
Posted January 02, 2018 - 09:17 PM
I've seen utility trailers for more money.
#7 dropped82 ONLINE
dropped82
    Nut Case
  • 2,633 Thanks
  • 1,869 posts
Posted January 02, 2018 - 09:56 PM
That's definitely cheaper than what I have. I gave 1k for my similar 16' and it needed tires, lights, and wiring.
#8 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted January 02, 2018 - 10:53 PM
I was looking at this one. https://www.flatrock...r=xAllInventory
#9 bbuckler OFFLINE
bbuckler
  • 3,660 Thanks
  • 3,190 posts
Posted January 02, 2018 - 11:24 PM
Same Trailer both are CM Trailers
#10 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,554 posts
Posted January 02, 2018 - 11:52 PM
That doesn't seem like a bad price, if you were going to always be hauling cars and other heavy loads I might be worried. But if your hauling garden tractors and other small tractors I think it would work great.
Although you could haul more garden tractors if you had a trailer like mine :thumbs:
  • olcowhand, KennyP, bbuckler and 1 other said thanks
#11 bbuckler OFFLINE
bbuckler
  • 3,660 Thanks
  • 3,190 posts
Posted January 03, 2018 - 12:15 AM
Requires a CDL in Texas for a gooseneck. Had a friend that had to go to court over pulling a gooseneck dump trailer.
  • KennyP and Reed Breneman have said thanks
#12 adamjd200 OFFLINE
adamjd200
  • 2,084 Thanks
  • 2,200 posts
Posted January 03, 2018 - 12:30 AM
I have a 16' and a 4x8, it's nice to have the smaller trailer when the big one is not necessary.
Edit, here is my dodge and 16' Bri Mar 7000gvw leaving a show last June.
Edited by adamjd200, January 03, 2018 - 12:34 AM.
#13 poncho62 ONLINE
poncho62
  • 1,981 Thanks
  • 1,735 posts
Posted January 03, 2018 - 06:27 AM
Those trailers for $1000 do not have brakes.....2 or 3 garden tractors plus other stuff is getting up there in weight, I would want trailer brakes for that.....just sayin'
  • grnspot110, Leonard VanCamp and Reed Breneman have said thanks
#14 cootertom OFFLINE
cootertom
  • 1,614 Thanks
  • 835 posts
Posted January 03, 2018 - 07:15 AM
Last 2X8X16 cost about 16.50 each plus taxes. Figure if it's not pressure treated and sits outside in 2 to 3 years you'll be dropping another $200 in it plus new hardware.
#15 KennyP ONLINE
  • 40,032 Thanks
  • 46,727 posts
Posted January 03, 2018 - 07:44 AM
My 16' trailer is the same as the original post, but it was used and abused when I got it. Had to pull the floor and straighten the cross members due to over loading. Put 6 new boards in it and a 5000 lb. winch on the front. I can get 4 tractors on it, but very little else. Been very happy with it.
