Chains for the Blower Tractor
17 replies to this topic
#16 KennyP ONLINE
  • 37,582 Thanks
  • 45,541 posts
Posted January 03, 2018 - 11:03 AM
Do you even get any snow!
Not often! And it usually melts off within a few days. But we have gotten '10" of Partly Cloudy' before!
  • Cjet69 and Mark 149 J. have said thanks
#17 Cjet69 ONLINE
Cjet69
  • 496 Thanks
  • 293 posts
Posted January 03, 2018 - 07:30 PM
After using these pliers a bit I have found that if the cross chain hooks are crimped down tight on these chains that the spreader jaws won't get a good grip and will slip. They work fine on some old car chains that I have, but the smaller set of pliers that Tirechain.com offers might work better for these chains. They are also cheaper. I may try modifying the jaws some to see if I can make them fit better.
I did find that if I start with a pair of nippers then the spreader jaws work just fine.
  • Mark 149 J. said thank you
#18 JBRamsey ONLINE
JBRamsey
  • 1,412 Thanks
  • 813 posts
Posted January 04, 2018 - 11:04 PM
Growing up in the south with a daddy that felt four wheel drives only got you stuck where no one could get to you, he always used chains for the little snow that we got. When I got big enough to do it, it became my job to ensure his pickup had weight in the back and chains on the tires.
He wanted the chains tight. I learned to cheat the system. I dropped the air in the tires, mounted the chains and aired the tires back up.
