Never had this happen before......
20 replies to this topic
#1 poncho62 ONLINE
poncho62
  • 1,613 Thanks
  • 1,615 posts
Posted December 31, 2017 - 12:57 PM
Quite cold here today -20c (0F).......anyways, had my tractor going yesterday, so thought I would do a bit of snow cleanup......K301 Kohler.....Had a hard time starting it, cranked real slow, put boost on battery etc....When it finally started, a bunch of oil came out behind carb, thinking the valve cover vent. After running a minute or so, it stopped.........Never had this happen before. I am thinking if I blew a gasket, it would keep leaking. Think maybe my oil is just to cold and thick?...Its 10w30
  • hamman, KennyP and boyscout862 have said thanks
#2 KennyP ONLINE
  • 37,537 Thanks
  • 45,525 posts
Posted December 31, 2017 - 01:13 PM
Never started one in those temps, but a block heater might help!
  • poncho62, hamman, jimbobbillyray and 2 others have said thanks
#3 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted December 31, 2017 - 01:16 PM
-20 here today also. Oil would be thick for sure. Maybe the breather is gummed up and needed cleaning. Just a guess.
Noel
  • poncho62, hamman, boyscout862 and 1 other said thanks
#4 John Arsenault ONLINE
John Arsenault
  • 2,413 Thanks
  • 1,164 posts
Posted December 31, 2017 - 01:17 PM
Hmmmmm, I have a K301 in my horse and it never has a hard time starting in cold and I have never had any type of oil dump occur so something must be wrong. I would think that if you blew a gasket as the oil warmed up it would become worse not better as the oil would get thinner and run out even faster. Also if it were from bad rings or excessive blow by you would find it to get worse once its warmed up not better.
Only thing that I think that is different between yours and mine is I use synthetic oil, synthetic oil remains thinner even in the coldest conditions. I run Mobile 1 0-40w European formula all year round.
  • poncho62, hamman, jimbobbillyray and 1 other said thanks
#5 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,134 Thanks
  • 4,896 posts
Posted December 31, 2017 - 01:52 PM
Crankcase breather has iced over on a previous run.
  • poncho62, hamman, boyscout862 and 2 others have said thanks
#6 dropped82 ONLINE
dropped82
    Nut Case
  • 2,455 Thanks
  • 1,802 posts
Posted December 31, 2017 - 01:57 PM
I started my P220 Onan in subzero a few days ago. It was noisy at first. Just don't push it too hard until it warms up. I let my run for 15 minutes or so at about half throttle to build some heat before loading it up. I also just use 30w so your 10w would actually be better for it in the colder temps on first start.
#7 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,243 Thanks
  • 5,552 posts
Posted December 31, 2017 - 02:12 PM
I thinking too cold and oil too thick.  ???
  • poncho62, hamman and boyscout862 have said thanks
#8 poncho62 ONLINE
poncho62
  • 1,613 Thanks
  • 1,615 posts
Posted December 31, 2017 - 04:03 PM
Thanks guys....expecting some snow tonight, so will see what happens tomorrow
#9 boyscout862 ONLINE
  • 12,552 Thanks
  • 9,046 posts
Posted December 31, 2017 - 04:16 PM
Cover it with an old blanket and put a 60w drop light under the engine. Even a little heat can thin the oil. It has helped me with old trucks many times. Good Luck, Rick
  • poncho62, Gtractor, lyall and 2 others have said thanks
#10 EricFromPa OFFLINE
EricFromPa
  • 3,537 Thanks
  • 3,072 posts
Posted December 31, 2017 - 04:41 PM
What brand of oil do you have in it?
I had Coastal 10w30 in my walk behind snow blower last year and the oil was so thick that it looked like a big glob of glue on the dipstick. It pushed through the breather when I started it.
I could not start it with the pull rope. Had to drag out the extension cord and plug in the 110v starter.
I let it warm up good and drained the oil and put Castrol High Mileage 10-w30 in it which is a Part synthetic oil. It doesn't get nearly as thick as that cheap oil I had in it.
It was +5*F with -11*F wind chill here last evening when I started the old blower to blow out the front of the house and even though it felt stiff I could use the pull start.
The straight 30 wt bar oil for my chainsaw would not come out of the jug. Was going to cut up some wood but that didn't happen.
Edited by EricFromPa, December 31, 2017 - 04:42 PM.
  • poncho62, Alc, boyscout862 and 2 others have said thanks
#11 poncho62 ONLINE
poncho62
  • 1,613 Thanks
  • 1,615 posts
Posted December 31, 2017 - 04:42 PM
My dad used to build a fire under the old Cat bulldozers years ago.......lol
I have a heat lamp I may strap under there for an hour or so if its too cold.
  • boyscout862, Sawdust and Leonard VanCamp have said thanks
#12 poncho62 ONLINE
poncho62
  • 1,613 Thanks
  • 1,615 posts
Posted December 31, 2017 - 04:45 PM
Its Canadian Tire house brand.....I added some oil after and it did seem thick coming out of the jug.....I should try some synthetic I guess.
#13 Mncdriver OFFLINE
Mncdriver
  • 24 Thanks
  • 16 posts
Posted December 31, 2017 - 05:24 PM
My guess is crank case pressure.  Just make sure there is no blockage.
#14 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,991 Thanks
  • 9,637 posts
Posted December 31, 2017 - 05:37 PM
Wind chill is the effect of the wind evaporating moisture off of your skin and lowering your body temperature. Wind chill doesn't have an effect on an engine. There is no moisture evaporating off and removing heat.
#15 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,243 Thanks
  • 5,552 posts
Posted December 31, 2017 - 05:40 PM
I don't think there is anything wrong with your engine, as I said before "oil too thick" doesn't do it's job right and stuff happens.
I think most engine manufactures recommend thinner oil in cold temps.
  • poncho62, boyscout862 and Sawdust have said thanks
