Needing cylinder rebuilt
needing a cylinder rebuilt
9 replies to this topic
#1 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted December 31, 2017 - 12:15 PM
I am needing a welded hydraulic cylinder rebuilt. I don't have the tools to rebuild it. Any one want to help me out
#2 boyscout862 OFFLINE
  • 13,427 Thanks
  • 9,379 posts
Posted December 31, 2017 - 04:00 PM
I would think that you have several hydraulic shops in the Atlanta area. Most can rebuild cylinders and valve spools. Check the price for a new one, with Bailey Sales . Good Luck, Rick
#3 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted December 31, 2017 - 04:39 PM
I have one local, but I like to support guys in the hobby. If I don't get any bites, on Tuesday I will take it into the shop
#4 EricFromPa OFFLINE
EricFromPa
  • 3,961 Thanks
  • 3,235 posts
Posted December 31, 2017 - 05:23 PM
Know someone that has a lathe?  Chuck it up in a lathe and cut the weld out. Then you can look for seals.
I had my brother take a small lift cylinder to work with him to rebuild. He works at Caterpillar himac and he rebuilds cylinders every day.
He said Normally anything that small is a throw away because the parts and labor cost more than the cylinder is worth. But they had all of the seals in stock and because my brother rebuilt it on his free time while waiting for a piece to come out of the CNC lathe it only cost me a couple bucks for seals and some beers for my bro.
He said said CAT gets around 20k $$$ to rebuild or make one of the big lift cylinders from a 30 ton CAT 730 rock truck.  They make everything on the cylinders in house from CNCing new pistons to custom length barrels.
  • ducky, KennyP, Leonard VanCamp and 1 other said thanks
#5 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted December 31, 2017 - 06:31 PM
I would even consider buying new but I can't find any suitable odd ball cylinders
#6 secondtry OFFLINE
secondtry
  • 2,109 Thanks
  • 1,508 posts
Posted December 31, 2017 - 10:41 PM
If you were to post a picture showing the whole cylinder beside a tape it is possible some one has one around that could work. Don
  • Mark 149 J. said thank you
#7 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted January 02, 2018 - 03:31 PM
Pics
13.5 inches closed from center to center
19.5 inches fully open center to center
#8 secondtry OFFLINE
secondtry
  • 2,109 Thanks
  • 1,508 posts
Posted January 03, 2018 - 02:00 PM
If you have an equipment recycler around that looks like the reel lift cylinder from an old Heston swather.  Don
#9 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted January 04, 2018 - 07:51 AM
Talked to 3 shops. I am looking at 275 to 350 to get it rebuilt
#10 EricFromPa OFFLINE
EricFromPa
  • 3,961 Thanks
  • 3,235 posts
Posted January 05, 2018 - 12:48 AM
Would this work? Heck of alot cheaper than rebuilding yours.
https://www.ebay.com...ity!15554!US!-1
You might be able to change the ends?
Here is a AMF 1414 cylinder Cheap. But it has some rust on the end of the rod. It doesn't look to bad and it might clean up.
https://www.ebay.com...7wAAOSwU1RZg3r1
  • Alc and Mark 149 J. have said thanks
