Extending a Kohler K series crankshaft
9 replies to this topic
#1 James Bosma OFFLINE
James Bosma
  • 1,589 Thanks
  • 755 posts
Posted December 31, 2017 - 09:08 AM
I have a real nice K321, but it is a short crankshaft
Has anyone made a adapter to extend the crankshaft in order to use a electric clutch in order to power a snowblower attachment
I do have use for the short shaft engine without the clutch, I can put it in my ploughing tractor with 3 pt. hitch
This would only be temporary till the other K321 I am getting rebuilt comes back
Dropping it off on Jan 2 2018 at the machine shop for measuring, boring, etc. not sure how long it will be gone for.
One guy I know has a good small engine machine shop in his garage, he's retired, along with the other 2 guys there, think it will be around $500 to $600 CAD to machine the block, parts and assembly.
Take him a box of unassembled K321, get it back in one piece and running.
Might better have a good working engine in the work tractor
  • DH1 and KennyP have said thanks
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted December 31, 2017 - 09:19 AM
Sounds like a good guy to know.
  • KennyP and James Bosma have said thanks
#3 poncho62 ONLINE
poncho62
  • 2,255 Thanks
  • 1,836 posts
Posted December 31, 2017 - 09:28 AM
My "K" engines in my Jacobsen Fords have the extended crank....It is a solid part of the crank at that end of the engine. The flywheel end has a bolt on piece to drive the tractor. I cannot see how you could bolt on any sort of adapter to the front end. I think it would be easier to adapt something at the flywheel end or find a crank (engine) with the longer crankshaft
Edited by poncho62, December 31, 2017 - 09:31 AM.
  • boyscout862 and James Bosma have said thanks
#4 James Bosma OFFLINE
James Bosma
  • 1,589 Thanks
  • 755 posts
Posted December 31, 2017 - 09:58 AM
Sorry should of mentioned the flywheel drives hydrostat, Its a Massey MF 14
Briggs offered one but its around 1 " in diameter
Briggs & Stratton # 691779 EXTENSION-CRANKSHAFT
Just some thoughts on this cold winter day
-23 Celsius around 10 below F
-31 Celsius wind-chill around 24 below F
Too cold to go outside and can't heat shop in this weather
#5 KennyP ONLINE
  • 41,519 Thanks
  • 47,427 posts
Posted December 31, 2017 - 10:03 AM
I have an M16 with just a little stub sticking out. Sweet running engine, though.
#6 James Bosma OFFLINE
James Bosma
  • 1,589 Thanks
  • 755 posts
Posted December 31, 2017 - 10:20 AM
I might be able to get a Kohler K341 like that, might get it if he still has it
Used on a Zero turn I gather
The one on mine is about 2 inches long from back of block,
sorry, no picture
#7 KennyP ONLINE
  • 41,519 Thanks
  • 47,427 posts
Posted December 31, 2017 - 10:41 AM
sorry, no picture
I'm pretty sure that's where it came from.
#8 KC9KAS OFFLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted December 31, 2017 - 10:57 AM
That may be a little too short for an extension! Looks like a crank replacement is in order!
#9 KennyP ONLINE
  • 41,519 Thanks
  • 47,427 posts
Posted December 31, 2017 - 11:18 AM
Yeah, that's what I was thinking! I have a plan for it that won't need a shaft there! Just gotta get warmer so I can start figuring it all out!
  • James Bosma said thank you
#10 dodge trucker ONLINE
dodge trucker
  • 2,914 Thanks
  • 3,533 posts
Posted December 31, 2017 - 01:09 PM
If that were me I'd be looking for a crank to swap into that long block, that would be compatible with one of my machines. wouldn't be the1st crank swap I'd done to be able to make an engine work for my application.
