ST16 breathes fire
4 replies to this topic
#1 nev OFFLINE
nev
  • 12 posts
Posted July 02, 2011 - 08:31 AM
Hey everyone one quick question. When you remove the muffler from your OH160 tec. does it blow about 6" of blue flame?
Thanks O and Happy 4TH
#2 MH81 OFFLINE
Posted July 03, 2011 - 04:31 PM
I'd say the timing is a little off, or the mix a little rich. If dark out, yeah you will see a little flame... (Cool Huh? He, He, He,!)
#3 nev OFFLINE
nev
  • 12 posts
Posted July 04, 2011 - 08:13 AM
timing wize everything is set to the proper specifications and checked and reset several times.I have two OH160 engines and they both do the same thing. When its running you can see into the cylinder around the valve. I have never seen anything like it, not stock anyway. The engine has plenty of horsepower and is on my sons 69 ss12 pulling tractor.
Ill try to lean the mixture some.
#4 MH81 OFFLINE
Posted July 04, 2011 - 09:21 AM
if you're pulling, i would leave it alone. It's probably better that way anyways. With no muffler, it's probably normal function and if you lean it up too much, it will have a tendency to run hotter and have less power.
  • nev said thank you
#5 nev OFFLINE
nev
  • 12 posts
Posted July 05, 2011 - 03:40 PM
I agree plus I have other things to get done on it yet
