standard differential question
1 reply to this topic
#1 Bob White12 OFFLINE
Bob White12
  • 141 Thanks
  • 137 posts
Posted December 30, 2017 - 03:04 AM
so it was a nice warm day today so I decided to try to free up my standard Walsh differential well one anyways. I already freed one up but it doesn't work. its pretty hard to explain but basically this block goes groves on this hub on the wheel.
anyway there is a spring on there the spring is still strong but once it falls out of the block it doesn't go back into the block I have to hit it back in. I'm also trying to free up the hub on the other side but it still hasn't given up.
#2 Alc ONLINE
  • 7,232 Thanks
  • 7,583 posts
Posted December 30, 2017 - 05:06 AM
I'm sure you'll free everything up . I was lucky the ratchet was just a little rusted up and a bit of PBlaster  freed it up quickly .  You might have to loosen the bolt and clean behind it to make it spring back .
Edited by Alc, December 30, 2017 - 05:07 AM.
