Tach purchase suggestions wanted
11 replies to this topic
#1 IamSherwood OFFLINE
  • 8,390 Thanks
Posted July 02, 2011 - 06:06 AM
I need to get myself a tach.
To be used on my older Tecumseh, and Kohler engines.
So far I've been winging it, but it's time to get more accurate.
What should I buy?
Thanks
#2 poncho62 ONLINE
poncho62
  • 1,276 Thanks
  • 1,487 posts
Posted July 02, 2011 - 06:38 AM
Heres one on ebay.......not the one I was looking for, but it says its for small engines
Vibra Tach/Tachometer 670156 TECUMSEH Small Engine | eBay
#3 IamSherwood OFFLINE
  • 8,390 Thanks
Posted July 02, 2011 - 06:46 AM
Thats a Tach? Looks more like a twist off bottle cap opener. No blinky lights.
How's that thingy work?
#4 poncho62 ONLINE
poncho62
  • 1,276 Thanks
  • 1,487 posts
Posted July 02, 2011 - 06:53 AM
You got me.....lol
I just searched for small engine tach and that came up.....There was a square digital one I used to see on there, but cant seem to find it right now......
#5 JDBrian OFFLINE
  • 9,599 Thanks
Posted July 02, 2011 - 07:32 AM
It works by measuring the frequency of the engine vibration. Somewhere on here there is a thread on using one so if you do a search you should come up with some info. I use an optical tach. You put a small piece of adhesive backed reflective tape on what you want to measure and point the tach at it to get a reading. If you look at the photos in my recent 314 engine post in the JD forum you can see the reflective tape on the PTO sheave. I need to engage the PTO to use that. I also have a piece on the drive shaft and can get readings from either side of the engine if I am working on it to set the max. speed, idle speed etc. Actually heres a picture of the PTO
  • IamSherwood said thank you
#6 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted July 02, 2011 - 08:13 AM
Electronic Specialties Inc. Professional hand held automotive test equipment.
#7 IamSherwood OFFLINE
  • 8,390 Thanks
Posted July 03, 2011 - 06:31 AM
I just did a search, and there it was, right in front of me.
A sticky at the top of this forum. Hmmm
http://gardentractor.../vibratach-222/
Sounds like the answer.
Thanks
#8 Knott OFFLINE
Knott
  • 1 posts
Posted August 04, 2011 - 08:55 PM
The best one I have used is Design Technology Inc.'s Tiny Tach. Easy to setup, use & read. I will not use any other tach. Welcome To Tiny-Tach. Small and economical tachometers for gas and diesel engines.
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,476 Thanks
  • 2,811 posts
Posted August 04, 2011 - 09:23 PM
i use a stewert-warner hand held one here, got at an auction for $25. It read 0-4000rpms, in either direction. You just hold it to the end of the turning shaft.
#10 olcowhand ONLINE
  • 38,802 Thanks
  • 30,701 posts
Posted August 05, 2011 - 10:04 AM
I have a "vibra-tach", and recently got an optical like JDBrian has. The vibra works great, but the optical is much more accurate. If wanting one to stay on the tractor, then "Tiny-Tach" is the easiest to mount.
#11 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted August 05, 2011 - 10:08 AM
Thanks
The Vibra Tach was a required tool for Briggs dealers
#12 ducky OFFLINE
  • 1,964 Thanks
  • 4,087 posts
Posted August 05, 2011 - 10:15 AM
If you already have DMM with RPM capabilities all you need is is the pick up to clamp to the plug wire. Just remember a lot of 2 cylinder engine fire twice, top and bottom of stroke, during each Revolution. In that case you could use the 2 cycle setting or divide the reading in half.
