Kohler twin question
3 replies to this topic
#1 Alltractoredup OFFLINE
Alltractoredup
  • 16 Thanks
  • 33 posts
Posted December 25, 2017 - 12:35 PM
Does anybody have experience and success putting a carb from a CH25 on a ch22 stock engine with success? Im just getting started and thought someone may help out.
#2 Bolens 1000 ONLINE
  • 14,922 Thanks
  • 18,112 posts
Posted December 26, 2017 - 11:47 AM
you need to run the model spec and serial numbers to determine if the numbers will interchange, with so many changes between models I would highly doubt they fit
#3 Alltractoredup OFFLINE
Alltractoredup
  • 16 Thanks
  • 33 posts
Posted December 26, 2017 - 08:50 PM
It bolts up, curious if the additional air/fuel would be too much for the CH22
#4 dodge trucker ONLINE
dodge trucker
  • 2,307 Thanks
  • 3,020 posts
Posted January 09, 2018 - 07:37 PM
no as they only "take" as much as the V.E. of the engine will allow...... that's how you could put an 850 CFM 4 barrel on a small V8 and not flood it out.....
carb CFMs is like electricity.... just because you run a 20 amp breaker doesn't mean there's 20 amps going thru that line at any given time.... if the breaker's on, and nothing's plugged in and running, there is no current flow.. same way with a carb. Even if rated for 850 CFM, if the engine will only inhale 245 CFM then you will only GET that 245 CFM thru that carburetor.
  • JCraig said thank you
