Picking up a Cub 1872 today
19 replies to this topic
#1 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted December 24, 2017 - 06:02 AM
A fellow at work asked if I wanted an old Cub 1872 , the story goes he bought it new ( in the 80's ?) when he lived in NY state . Moved back in our area since early 90's used it for his part time mowing business until he got a zero turn . Gave it to another fellow at work to have at his gun club , they used it for years but it seems that equipment that different people use sometimes doesn't get the service it should Anyway the driveshaft either broke or what they use  for a U-joint and it tore apart the hydraulic lines . It was pushed aside and was going to be scraped . He ended up getting it back and was going to fix it . It's been sitting in his shed now  a few years .  He figured since I enjoy the old David Bradley's I might want a old tractor project . A side note here : My NEWEST tractor that does all my mowing , leaf pick-up ect  is the 1983 John Deere 318 so this one is newer lol, . I don't know what shape it's in now from sitting but will find out in a few hours .
  • KennyP, boyscout862, EricR and 5 others have said thanks
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted December 24, 2017 - 06:09 AM
The gun club lawn mowing machine? Hopefully it was not put out of it's misery after the shaft let go.
  • Alc, KennyP, boyscout862 and 3 others have said thanks
#3 KennyP ONLINE
  • 37,537 Thanks
  • 45,525 posts
Posted December 24, 2017 - 07:30 AM
I found this for the driveline:
https://screenshots....ww.cubcadet.com
  • Alc, boyscout862 and Mark 149 J. have said thanks
#4 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted December 24, 2017 - 08:31 AM
Looks like it will have to wait , he sent me a text that he  is battling gout again and it's painful to be on his feet . I'm off this week , he works afternoons so maybe this coming week
  • KennyP, boyscout862, HANKG and 1 other said thanks
#5 DanielG ONLINE
DanielG
  • 54 Thanks
  • 60 posts
Posted December 24, 2017 - 09:53 AM
good luck with gettin it home and gettin it running and have a merry christmas
#6 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,168 Thanks
  • 1,227 posts
Posted December 24, 2017 - 10:30 AM
That's a great price Al!!!
Merry Christmas!
#7 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted December 24, 2017 - 01:36 PM
Merry Christmas Al and Mary
#8 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted December 27, 2017 - 07:32 PM
Brought it home today Besides the driveshaft problem the bolts on the right side axle housing are stripped might not b charging. I left it on the trailer I want to pressure wash it first but that won’t be until at least next week or when it gets warmer
Edited by KennyP, December 28, 2017 - 07:33 AM.
Adjust Gravity
  • KennyP, EricR, MolonLabe and 1 other said thanks
#9 Cat385B ONLINE
    HAZMAT CAT
  • 13,781 Thanks
  • 9,920 posts
Posted December 27, 2017 - 07:54 PM
You're going to have a busted hood if that backhoe gets any closer to it.
#10 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,168 Thanks
  • 1,227 posts
Posted December 27, 2017 - 08:22 PM
That's going to be fun project!
#11 secondtry OFFLINE
secondtry
  • 1,688 Thanks
  • 1,288 posts
Posted December 27, 2017 - 08:57 PM
 Did they scrap the deck or did you get it.  Don
#12 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted December 28, 2017 - 06:27 AM
I got the 60" deck , it might have been removed for transit or to look at the broken driveshaft . He told me the deck was made by Haben for the Cub , option maybe ? Was pretty heavy , we used my HF atv winch that I temporary mounted on the trailer , pulled the tractor up first then ran the cable under it to pull the deck up . He also gave me a set of rear Carlisle tires , not a V type but atv ones . The picture posted is one he sent the day he pulled it out of his shed , the orange backhoe is a Dig-It  pull behind back-hoe . It was one he bought from work when they started buying small track excavators . There nice little machines , the hydraulic drive wheels unlock for towing , there's a drop down tongue with a hydraulic " shoe " that it like a center outrigger that will raises the tongue for hooking up to a tow vehicle .  The stripped bolts in the axle housing , is that common ?
  • KennyP, Mark 149 J. and secondtry have said thanks
#13 KennyP ONLINE
  • 37,537 Thanks
  • 45,525 posts
Posted December 28, 2017 - 07:36 AM
Those stripped bolts may have led to the drive shaft failure. Is that an aluminum rear? Might be able to heli-coil, but I would use Loctite with them to make sure they stay put.
  • Alc and Mark 149 J. have said thanks
#14 EricR OFFLINE
EricR
  • 642 Thanks
  • 397 posts
Posted December 28, 2017 - 11:38 AM
Al, nice tractor you got there, I have a 2072 with a command swap so I do know a little about these, but anyway yes the drive shaft thing on those are a problem.  And if the rear bolts are broken look around the rear more as there could be more problems...
You will have to pull the rear to fix those broken bolts right. The Haban deck is a nice one but they are VERY heavy...
  • Mark 149 J. said thank you
#15 DanielG ONLINE
DanielG
  • 54 Thanks
  • 60 posts
Posted December 29, 2017 - 08:35 AM
looks good a lot of problems but there ant nothin can't be fixed good luck with it in the new year
