Wheel weights question
#1
OFFLINE
Posted December 23, 2017 - 09:43 AM
#2
ONLINE
Posted December 23, 2017 - 03:10 PM
#3
OFFLINE
Posted December 23, 2017 - 05:58 PM
#4
ONLINE
Posted December 23, 2017 - 06:25 PM
if the Cub has 24" WHEELS (not tire diameter) then yeah. but at the same time, any tractor with 24" wheels is larger thna a GT....
#5
ONLINE
Posted December 23, 2017 - 11:38 PM
He is talking about the Farmall cub, not the garden tractor line, both international
They should fit, just check to see if the bolt holes are on the same spacing, believe they use the same front and rear rims.
I'm using a set of the 12 " front weights for them on the rear of my Massey MF 14
- dodge trucker said thank you
#6
OFFLINE
Posted December 24, 2017 - 03:41 PM
Rear wheel weights from a Farmall A/B WILL fit on the rear of a farmall Cub. I have a set on our 1955 LowBoy. If I remember right the difference is that the Cub wheel has smaller bolt holes than the A/B wheel does. The bolt pattern is most definitely the same though.
Edited by IHCubGuy, December 24, 2017 - 03:42 PM.
- James Bosma said thank you
