Ford lgt 125
7 replies to this topic
#1 mikesharley OFFLINE
mikesharley
  • 1 Thanks
  • 1 posts
Posted December 20, 2017 - 11:45 PM
How do I tighten my drive belt on my lgt 125 it keeps cming off when I push in the clutch mines a manual
  • case1man said thank you
#2 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted December 21, 2017 - 05:25 AM
:wave: Welcome to the forum! Which LGT 125 is it? Pre '72, '73-'76 open side, or '77-'83 closed side?
  • boyscout862 and case1man have said thanks
#3 poncho62 OFFLINE
poncho62
  • 1,987 Thanks
  • 1,740 posts
Posted December 21, 2017 - 05:32 AM
An LGT125 is a hydro......You likely have an LGT120 or 100 that someone has changed the hood on.......or it is a pre 1972, whereas it's not an LGT. Some pics would help and the model number of the Kohler engine.
That said, you probably need a new belt or you have a pulley out of whack. I would remove the fender pan, so you can see whats going on as all this is under the seat. That is if it's an LGT. The older pre 72 ones, you can see whats going on as its on the side.
#4 boyscout862 OFFLINE
  • 13,437 Thanks
  • 9,384 posts
Posted December 21, 2017 - 09:11 AM
Welcome to GTT. That is a good machine. Pancho62 is correct that an LGT125 is a hydro. We can help you if you post clear pics. The footer of KennyP's post gives instructions on how to post pics. When identified you can go into our Manuals Section and download the manuals for your GT(3 free per day). Good Luck, Rick
#5 HALFSCALE OFFLINE
HALFSCALE
  • 505 Thanks
  • 533 posts
Posted December 22, 2017 - 03:43 AM
125's came available in both hydro and gear drive.
#6 poncho62 OFFLINE
poncho62
  • 1,987 Thanks
  • 1,740 posts
Posted December 22, 2017 - 05:54 AM
Turns out that the tractor is a close sided 120....The guy asked the same question on a Facebook group, at least I figure its the same guy
As for gear drive 125s, never seen one......my understanding is that the "5" meant it's a hydro
  • KennyP, boyscout862 and case1man have said thanks
#7 case1man OFFLINE
case1man
  • 202 Thanks
  • 137 posts
Posted December 22, 2017 - 10:28 AM
All ford 125,s was hydro only ones I know that was both was the olivers
  • HALFSCALE and boyscout862 have said thanks
#8 HALFSCALE OFFLINE
HALFSCALE
  • 505 Thanks
  • 533 posts
Posted December 22, 2017 - 01:20 PM
Learn something new every day.
