Another 646 Repower
9 replies to this topic
#1 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted December 17, 2017 - 06:58 PM
Winter is here in Helena Mt. and I figure it's time to get on with the winter project. Last winter I picked up another 646 up the road in Great Falls Mt. After rebuilding the rear end and the front end I figure it's time to remedy the smoking Onan under the hood. My last 646 repower was done using an 18 hp Kohler V-twin so I have chosen to use the same engine again. Everything on this tractor works well so the swap out should be easier to do than the last one. Unfortunately this tractor is not complete and some 3 point fabrication as well as new hoses will be needed. I will attempt to do a better job of documenting this process and posting the pics.
  • olcowhand, KennyP, boyscout862 and 2 others have said thanks
#2 secondtry OFFLINE
secondtry
  • 2,109 Thanks
  • 1,508 posts
Posted December 17, 2017 - 08:18 PM
From what i can see that is there it makes a complete three point fabrication seem trivial. Nice tractor  Don
  • Case-Closed and Mark 149 J. have said thanks
#3 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,686 Thanks
  • 1,508 posts
Posted December 17, 2017 - 11:17 PM
Nice tractor!
I would love to find a 646 like that one!  I've never owned one but every time I see one they look to be well built.  I would to find one and put a diesel motor in it.
  • Case-Closed and secondtry have said thanks
#4 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted December 18, 2017 - 08:50 PM
I considered a Z482 Kubota diesel for a while but I live in a place that commonly hits 30 below zero and diesel engines dont like that a whole lot. My other 646 has a Kohler V-twin I stuffed in it a few years ago. Starts easily anytime, while my KE-70 diesel in the Suzue 150 is a bugger to start. One other problem, diesels are pricey, even used ones, and most don't come with a flywheel, bell housing or a pump drive which adds several hundred dollars to the cost of a used engine with an unknown past.IMG_0886.JPG
Edited by Case-Closed, December 18, 2017 - 08:52 PM.
  • KennyP and Mark 149 J. have said thanks
#5 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted December 20, 2017 - 10:28 PM
Got home from work tonight to find this big crate on my front porch.
It was too big for me to drag into the shop with a foot of snow on the ground so I used the operational Case 646. The crate contained the new Kohler twin that is going into my dead 646. The engine and tractor are now getting to know each other before the procedure begins.
  • olcowhand, KennyP, Leonard VanCamp and 1 other said thanks
#6 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 2,686 Thanks
  • 1,508 posts
Posted December 20, 2017 - 10:30 PM
Christmas came early!
  • KennyP and Case-Closed have said thanks
#7 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted December 26, 2017 - 07:38 PM
I got a chance to tear into the dead 646 over the weekend and here's the proof. I got the party started with an oil drain by removing the plug in the travel control valve and cranking the engine with spark plugs removed and fuel lines plugged. Once the oil was gone I proceeded to pull off anything that might get in the way.
Next I removed the oil tank trying not to make a mess with the residual oil in the tank and yes I got it all over the floor. After that came the cooler and tank supports.
The fuel line got clamped off, wires removed, choke, throttle, fuel pump vacuum and clutch contols followed. I marked the frame with a paint stick to indicate the location of the front pully just in case I decide to use the stub shaft to drive a mower.
There are four bolts holding the engine to the frame and four more the pump mount to the engine. Onan's are heavy pigs and extraction is best done with a cherry picker and a chunk of chain.
I have a lot of grease removal to tend to and also a steering pawl bushing to install and my bucket control valve is leaking. With a little luck she will be ready to work in the spring.
Edited by Case-Closed, December 26, 2017 - 07:45 PM.
  • olcowhand, KennyP, gopher and 1 other said thanks
#8 Cat385B ONLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted December 26, 2017 - 11:09 PM
How much does a crate CH620 go for nowadays? Looks like my local market is about to be flooded with them for nowhere close to retail:
https://www.k-bid.com/auction/22832
  • olcowhand and Mark 149 J. have said thanks
#9 Case-Closed OFFLINE
Case-Closed
  • 309 Thanks
  • 155 posts
Posted December 27, 2017 - 12:28 AM
I gave up 900 bones and another 100 for shipping
#10 Utah Smitty OFFLINE
Utah Smitty
  • 1,705 Thanks
  • 1,789 posts
Posted April 06, 2018 - 02:38 PM
Seems like a great price for the engine.
I just bought a Case 444 with tiller, mower, blade, 3pt, and broken conrod (though no hole in block). I'd like to put another engine in it.  I have a couple 16 hp engines--a Briggs flat twin, and a Kohler Command V-twin, plus a Honda 16hp V twin.
Do you find 18hp to be enough engine, esp. with your loader?  Mine won't have a loader, but it will be used to mow with it's 60 inch deck and till.
Smitty
