Steering gears
h14 steering
6 replies to this topic
#1 BolensH14 OFFLINE
BolensH14
  • 2 Thanks
  • 12 posts
Posted December 16, 2017 - 10:03 AM
Once I finish the axle seals my next project will be pulling the badly cracked steering wheel.  The steering is VERY sloppy and I see that the pinion gear is very worn and the shaft bushing must be too.  Assuming I can get the pin out of the shaft above the pinion I may pull the shaft up wheel and all. (wheel has not budged when I tried to pull it.)
Anybody know where I can get a replacement pinion gear?  How about a better wheel?
Thanks
John
New Hampshire
  • hamman said thank you
#2 boyscout862 ONLINE
  • 12,577 Thanks
  • 9,053 posts
Posted December 16, 2017 - 11:18 AM
We have several sponsors who deal with Bolens. Check with them. They are all helpfull with their knowledge too. Good Luck, Rick
#3 Bud W OFFLINE
Bud W
  • 315 Thanks
  • 298 posts
Posted December 18, 2017 - 09:22 AM
I have a 1256 Bolens that the pinion and sector gear were both badly worn and it got so bad I couldn't steer it and had to replace both.The hard part was getting the sector gear out of the "cradle that it's in. The brass bushings are in steel bushings that are tack welded to the cradle, I took my grinder and ground the 2 welds that hold the steel bushings in the cradle and tapped one side out. I got a good pinion gear and sector gear with new brass bushings for inside the steel ones and put it back together and tack welded the steel bushings back in. It now has nice tight steering.
#4 BolensH14 OFFLINE
BolensH14
  • 2 Thanks
  • 12 posts
Posted December 20, 2017 - 12:28 PM
Bud, you said you got good pinion and sector gears and bushings.  Where?
#5 Bud W OFFLINE
Bud W
  • 315 Thanks
  • 298 posts
Posted December 21, 2017 - 02:42 PM
I found a good used set on Ebay.
#6 Bud W OFFLINE
Bud W
  • 315 Thanks
  • 298 posts
Posted December 21, 2017 - 02:43 PM
If you know a good welder, they can be welded and re-ground.
#7 Bud W OFFLINE
Bud W
  • 315 Thanks
  • 298 posts
Posted December 21, 2017 - 02:44 PM
I got the brass bushings from one of the site supporters.
